Introduction: Boat With Motor
Today we will be creating a functional motor boat with very few materials.
The materials we need are a strong tape, two or more mouse pads 14 cm wide and
20 cm high, some small propeller or boat motor, batteries and a battery pad.
Step 1: Cut Pad's
You will fold the first mouse pad twice on the long side, the first fold will be at 3.5 cm, the half has to measure 6.5 to 7 cm
Step 2: One Strip
the other one you are going to cut it by one of its long parts and it has to measure 3.5 to 4 cm long
Step 3: Two Strips
and then you will do the same with the other part to have two equal parts
Step 4: Triangle
You are going to cut a triangle with a rounded edge, 3.5 cm high and 6.5 cm long.
Step 5: Back
You will stick one of the strips on one of the ends to close the back of the boat.
Step 6: Front
You will glue the other strip to the other end but not to close it. In fact, it has to end like the tip of an arrow and this tip has to have the measurements of the triangle that we cut.
Step 7: Arrow
You are going to put the triangle at the bottom of the arrow and stick it with tape.
Step 8: Tape All
You have to put tape on all corners and all parts where water can get in.
Step 9: Final
You're going to make a hole in the back of the boat, put the motor in the middle and glue it to the bottom of the boat as well as the battery pad.
