Introduction: Boaty Mcboatface! a Paper Boat Guide
In this guide I'll teach you how to make a cool paper boat that can even float in water!
For this guide You'll need to following items:
- A piece of A4 paper
- Scissors
Step 1: Create a Square Piece of Paper
Fold the paper into a triangle in order to make sure it's square. Press of the diagonal line created with your finger to tighten the square.
After that, use the scissors in order to cut the paper.
At the end of this step you'll be left with a square piece of paper.
Step 2: Fold the Square Into a Smaller Square
Fold the paper along the middle of it horizontally then vertically in order to make a smaller square (1/4th the size of the original square)
Step 3: Turn the Square Into a Triangle
Lift one of the four sides of the square and fold it from the bottom right corner to the top left corner in order to make a triangle. then flip the paper and fold the other 3 sides left opposite of the previous flip.
Step 4: Open
In this step you need to open the triangle we created from the middle and fold it into a new square.
You should open it from the middle and then pinch the two sides of the triangle and bring them together
Step 5: Open Up Your Boat
All you need to do now is pinch the two top side pieces of the square and pull them apart to reveal your boat
You can now also open up the base of the boat from below so it will stand right up!
Step 6: Viola Now You Have a Boat
Congratulation, now you have yourself a small paper boat you can place in your bath, sink or even a puddle in the road! :)
