Bobcat E80 Right Hand Catch Repair
Introduction: Bobcat E80 Right Hand Catch Repair
this is my first instructable.
had problems opening the hood to check fluids and charging the battery.
so when i FINALLY got it open i removed the Catch PN 7012749 or 7005859,
then after i inspected the mechanism i discovered the lever to pin gap was too great to allow full movement of the pin.
Step 1: Dissassembly
remove E-clip A
remove tension from spring E by moving leg F
slide Hex pin to the Left. spacer B will fall off. then the Lever C will fall off. STOP
do not completely remove Hex pin.
Step 2: Lever
right side is the old
Left side is what is used now
Step 3:
place lever in opening.
slide Hex pin through lever C. if Pin will not slide then loosen 4 screws G
slide Hex pin through spacer B
complete sliding Hex pin till it stops.
add E-clip A
re-tighten 4 screws G
Step 4: Testing
place Phillips screwdriver in latching area
press down
latch should close around screwdriver shaft.
slide screwdriver out of latch
open handle to "Open"
re-install in Bobcat E80 in Open position.
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    2 Comments
    Swansong
    Swansong
    6 years ago
    Thanks for sharing :)
    DDW_OR
    DDW_OR
    Reply 6 years ago
    thank you.
    I wish instructable's had a Repair/Modification catagory.
