Introduction: Boho Headboard
Make a bohemian style headboard with unexpected materials.
Step 1: Watch the Video Tutorial Here!
Step 2: You'll Need
4'x6' piece of 1/2" thick plywood
400 wooden clothespins
Americana Decor Chalky Finish paint in Innocence Pink and Serene Blue
Rit Dye in Sunshine Orange, Apple Green and Golden Yellow
Sanding block or sander
Jigsaw
E-6000 or Wood glue
Paintbrush
Step 3: Prepare the Clothespins
Unwrap your clothespins
Pull off the spring in the center of each one
Prepare your Sunshine Orange Rit Liquid Dye in a large bowl with hot water
Soak 300 clothespins in the Sunshine Orange Dye for about 30 minutes
Step 4: Dye the Pieces
Dye the other 100 clothespins in Golden Yellow Rit Liquid Dye
Place the clothespins on newspaper to dry after 30 minutes
Dye all of the 300 joiner biscuits in Apple Green Rit Liquid Dye
Let them set for 30 minutes and then dry them on newspaper
Step 5: Prepare the Headboard
Mark the center of your plywood on the 6" wide side
Create the shape of the headboard with large sheets of newspaper
Cut and trace it on the plywood
Step 6: Cut and Paint
Carefully cut out the headboard shape and sand the edges
Paint the headboard in the colors you chose
*We used Serene Blue for the top and Innocence Pink for the center on this design
Step 7: Embellish
Arrange your dyed clothespins and joiner biscuits in your design
*Play around with them until you get it just right Carefully glue each piece down with either E-6000 Glue OR wood glue and let dry
