Boogie-Go Water Craft
Intro: Boogie-Go Water Craft
STEP 1: Parts and Tools
Boogie Board
Bildge Pump I used 1200 GPH MUST BE A SUBMERSIBLE PUMP
Waterproof Switch (Momentary on, or Switch on)
Batteries (2 6v 5 amp wired in series with switch)
PVC pipe and a couple fittings 1/2 inch sch40. refer to pic for type.
Large Plastic Ties
Quick Steel
Marine Sealant
Dremmel, Soldering kit, wire cutters, BRAINS
Large Plastic Ties
Quick Steel
Marine Sealant
STEP 2:
Take the Pump and Quick steel one end of the steering control piece to the pump.
STEP 3:
Cut the 1/2 inch pvc pipe to the debth of the board. You want it a tiny bit longer so it will spin once you tighten the control steering pieces together.
STEP 4:
Take the 1/2 inch Coupler to female threaded pipe fitting and Quick steel the other steering control piece to the coupler side.
STEP 5:
It should look like this when completed.
STEP 6:
You can now install onto Boogie board. You may want to drill a small hole for the wires to run from the pump up through the board to the top of the board for wiring. I ran mine on the outside part of the hole. I'm not worried because the board is styrofoam. It will not wear the coating off the wires.
STEP 7:
Here is what it will look like on the bottom and top view.
STEP 8:
Attaching the batteries to board with large zip ties. I zipped them pretty tight to hold them firmly.
STEP 9:
I added some extra PVC pipe for board support. You may not need this. I used the same type of large zip ties.
STEP 10:
This is the wiring stage of the project. Please look at the picture with yellow description boxes for visual understanding.
STEP 11:
I added this as an extra step to explain that you need a marine grade silicon sealant to cover and protect all electrical connections. MAKE SURE YOU COVER ALL EXPOSED ELECTRICAL CONNECTIONS PERFECTLY. DO NOT SKIMP ON SILICON.
15 Comments
thamby1 9 years ago
palombo5050 9 years ago
I built another one with a bigger pump and larger battery. It worked much better. Check out my waterproof switch using heat shrink.
ehudwill 12 years ago
wilgubeast 12 years ago
palombo5050 12 years ago
sunshiine 12 years ago
Lorddrake 12 years ago
l8nite 12 years ago
zazenergy 12 years ago
Good luck!
admin 12 years ago
Copy and past that code and it should work fine.
