Boombox 8 12v Internal Battery
Intro: Boombox 8 12v Internal Battery
(The main image is the new box with the same steps!!)
This BoomBox is my third one.
That one is more mobile, and so I wanted to achieve a better sound.
The main idea was to use a lighter materials with better durability.
The Components:
- wood (3 mm thick)
- bike battery - 12v (7 amp or more)
- battery charger (external)
- old head unit.
-6.5 inch speakers '
-wires speakers.
-2 switches.
- 2 metal L unit (for charging the unit as in the image).
-screws and bolts (you should look for as long as the wood)
- 5 metal stands (from old speakers).
STEP 1: The BEgin...
First of all i use a regular wood plates in the size of 12x10x18 inches. I use jig-saw for cutting.
Before you start the cutting, you should draw with pencil on the flat board what pieces to cut.
After that project i realize that the could be smaller.
STEP 2: Cut
Here is the list of holes you need to make before the assembley.
1. 6.5 inch speakers.
2. 2 power buttons.
3. head unit.
4. between speakers i add a tube for air. (I use bicycle chair tube for the air flow)- good for bass
Before is always better than later because of the mess and dirt it makes.
STEP 3: Connect All the Components
Here i just connected 2 L plated outside. their use for charging the internal battery.
Be careful with my way because if a steel will touch those 2 sides. For safety i added the red button, which disassemble the charging from the battery. I will also recommend to paint the negative and positive sides.
STEP 4:
Later on i placed the 12v battery in my case. I added some wood to catch it.
The stopper in the box is attached with epoxy glue (didn't want to drill again).
As u can see i also sold 2 connectors to the wires, and not soldering the battery for permanent because i wanted to have the choice of replace the battery when camping for few days.
STEP 5:
Here i connected all wires. For those who don't know how to do that, you should read your amp manuals as i did. it is really easy to find it on Google...
STEP 6:
As you can see i use speakers fabric for the bass.
i attached it with staple gun.
STEP 7:
As you can see i painted the box in white. It's taste decision and you should also but fabric and attach it from out side.
Also for taking care to the system i decided to use those clips for open it.
STEP 8: More Ideas...
Each head unit has 4X20 speaker output at least.
You should use old speaker connectors and connect them to it- that way you will be able to connect stereo speakers (or sub woofer also).
As for the legs, i will change it because of the beach sand (it sink..)
STEP 9: End and Recharge
So it work nice for 5 hours. Really good sound.
I am using simple car battery charger for charging it up.
Maybe in the future i will add solar power ability.
Enjoy music :-)
2 Comments
timi88 8 years ago
about 4-5 hours depends on the volume
tonyalejandrojr 9 years ago
nice! how long does the battery last with the head unit?
