Introduction: Beer Bottle Opener With Magnetic Top Catcher
My brother in law inspired this project, he has a bottle opener on the wall in his kitchen but every time you open a bottle you have to quickly catch the top or pick it up off the floor. I decided to make something a little better.
Wood from my scraps bin
Bottle opener from Amazon
Magnet 40 x 20 x 5 mm N52 from First4Magnets
Step 1: Selecting the Wood
I have a number of bits of wood lying around my workshop and selected this piece of oak and a couple of strips of western red cedar.
Step 2: Layup, Plane and Level
To add a little bit of detail I decided to rip the piece of oak lengthwise and insert the two western red cedar strips. This was glued with Titebond wood glue clamped and left to dry overnight.
Once the glue was dry I ran the finished piece through my thicknesser to get to a nice flat surfaces and then across the jointer to square of the edges.
Step 3: Cut the Parts
With the piece now level and square I chopped it to length for the individual openers, I was able to get five parts out of the length of oak I had. These were each 270 mm long.
I cut the corners off each piece to give it a bit of interest and not have it quite so Square. I ran a 45° bevel around the top and bottom going a little bit deeper on the top.
I also cut a couple of screw slots in the back to enable it to be hung on the wall. This was routed out using a Trend screw slot bit.
Step 4: Start of the Finishing
Because the grain of the wood I had used what's so beautiful I decided I wanted to enhance it rather than hide it.
This I did using three coats of Danish oil, each coat was left to dry for approximately 3 to 4 hours and then any excess oil was wiped off, between each coat a very light sanding using 240 grit sandpaper was also done. The final coat was left to fully dry overnight.
Step 5: Final Finish
To give the openers a bit of a protective finish I decided to add a few coats of polyurethane varnish. They are after all probably going to have beer spilled on them.
I had never applied at polyurethane varnish on top of a Danish oil finish so decided to try it out on a piece of scrap plywood that I'd also put oil on and the back of one of the openers.
I'm very pleased to report that the varnish took just fine, seems to have a fairly good at adhesion without any bubbles or other problems.
Step 6: Polyurethane Varnish
The varnish was applied using a 30 mm wide brush.
It has a satin finish which when dried looks beautiful.
I applied four coats of varnish leaving 4 to 5 hours between each coat, between each coat I knocked off any dust particles and bubbles that appeared in the finish using a 1200 grit sandpaper.
Step 7: Fitting the Magnet and Opener
Once the final coat of varnish had fully dried (over night) I routed out a hole in the back of the wood to take the rare earth magnet. The magnet is a 40 x 20 x 5 mm, neodymium, N52 type bought from First4Magnets. I took great care at this stage to make sure that I didn't burst through the front of the piece leaving approximately 5 mm of wood.
The magnet is held in place with a generous helping of hot glue.
I then flipped each piece over and screwed on the bottle opener using stainless steel pan head screws.
As you can see from the video the magnet grabs the tops very easily. It's an incredibly strong magnet and I think it will probably hold 20 to 30 bottle tops.
Woodworking Contest 2017
16 Comments
5 years ago
Simple, functional, and Voted. Great job!
I have a buddy that likes to buy old bottle openers from closed down bars and/or garage sales, then he uses old barn wood and makes a similar item. He can then call them "antique".
Reply 5 years ago
Matt, it's a shame how many pubs are shutting down ? I've never thought of them as a source of parts ? I'll be looking out in the future.
Thanks for the vote
5 years ago
I stuck a flexible fridge magnet below my opener and a cup so that the caps always end in the cup
Reply 5 years ago
Nice call Pat, belt and braces
5 years ago
You are a genius and a true craftsman.
You have just make the world a better better place!
Reply 5 years ago
Thanks very much :-)
5 years ago
A good source of those magnets is old hard drives. The magnets are glued(?) to metal frames and can be removed by clamping the frame edge in a vise and bending the other side of the frame away with pliers.
Reply 5 years ago
thank you! I also will make key chains from ram cards when I take my pld pcs apart.
Thanks for this instructable, I will be adding a magnet to my kitchen Coke opener.
Reply 5 years ago
Stick a magnet on it, a great little addition. I look forward to seeing pictures.
5 years ago
The absolute height of crazy
Mans only limit to ...
5 years ago
Very nice. I've made a few of these as gifts but I shaped mine to look like beer bottles. Mine were made out of a single piece of wood, but I really like the accent wood strips you put in there. I may need to incorporate that feature the next time I make some.
The other thing I did different was I used a couple extra magnets on the back to make the whole thing magnetic. Instead of mounting it on the wall, mine just stick on the door of the refrigerator.
Reply 5 years ago
Hi Rusty,
Thank you, yes the accent wood really works as a visual detail ?
I had seen this fixing method in some of the research it did for the project but I knew that at least three of the people who would be receiving these as gifts had in built refrigerators with an external wooden door.
I might stick an extra magnet or two in the next ones I do as I've been asked to make a few more ?
Reply 5 years ago
I'll probably be adding keyhole slots to any more I make so the recipient has the option of wall or magnetic mounting. I've got the keyhole bit, I might as well use it!
Reply 5 years ago
If you've got the bit already, you might as well add a couple of slots ?
5 years ago
Awesome design. I especially like the magnet top catcher.
Reply 5 years ago
Thanks Jason, I'm very pleased with my first Instructable
