Introduction: Bounce Effect Night Lamp
This effect can be explained as follows:
An array of 6 leds is arranged. The blinking starts from both the end, i.e.,0 and the 5th led and will continue till the 2nd and the3rd led respectively. Then the blinking will start in the backward direction, i.e., from the 2nd to 0 and 3rd to the 5th. This process will continue as long as the lights are off.
LDR(Light Dependent Resistance) is used to control the blinking of leds.
Step 1: Components Required:
1. Arduino Uno board (You may use any other also)
2. Leds x 6
3. Light Dependent Resistance(LDR)
4. Breadboard
5. Jumper wires
6. Resistors (1k)
7. USB cable
Step 2: Code
// Create array for LED pins
byte ledPin[]={4, 5, 6, 7, 8, 9};
int delayLed(50); //Delay between changes
int currentLed1=0;
int currentLed2=5;
int direction1=1;
int direction2=-1;
int sensePin=A0;
unsigned long changeTime;
void setup()
{ // put your setup code here, to run once:
for(int i=0, j=5;i<3 && j>2;i++, j--) //set all pins to output
{ pinMode(ledPin[i], OUTPUT);
pinMode(ledPin[j], OUTPUT); }
changeTime=millis();
void loop()
{ // put your main code here, to run repeatedly:
int val=analogRead(sensePin); //read the value of the LDR
if(val>1000) //setting condition for LDR
{ if((millis()-changeTime)> delayLed) //if it has been delayLed ms since last change
for(int i=0, j=5;i<6 && j>2; i++, j--) //turn of all LEDs
digitalWrite(ledPin[i], LOW);
digitalWrite(ledPin[j], LOW);
digitalWrite(ledPin[currentLed1], HIGH); //turn on the current LED
digitalWrite(ledPin[currentLed2], HIGH);
currentLed1+=direction1; //increment by the direction value
currentLed2+=direction2;
if (currentLed1==0) //to change the direction if we reach the end
direction1=1;
if(currentLed2==5 )
direction2=-1;
if(currentLed1==2)
direction1=-1;
if(currentLed2==3)
direction2=1;
else
for(int i=0; i<6;i++)
Step 3: Connections:
The connections for the night lamp are quite simple. Make sure you connect the leds to the correct Arduino pins.
Step 4: Run the Code
Now you have your own 'bounce effect' night lamp. You can modify as per requirements :)
