Introduction: Boutique Bow/Cheer Bow
Easy tutorial for making a boutique/cheer bow.
3 inch ribbon
3/4 inch ribbon or bling ribbon
wire or string
scissors
glue gun
ruler
lighter
Step 1: Supplies
Gather all of your supplies
Step 2: Measure
Measure your 3 inch, and 3/4 ribbon to desired length. I made this bow with ribbon that was 20inches long.
Step 3: Cut
Cut both pieces of ribbon.
Step 4: Find the Middle
Fold the 3 inch ribbon in half making a good crease to mark the middle of the ribbon.
Step 5: Cut the Ends
Fold the ends of the large ribbon in half and cut at a angle making a V shape. Then take your lighter and lightly burn the inside of the V so that the ribbon doesn't ravel.
Step 6: Fold Your Ribbon
Take one side of the ribbon and cross it over the other side making an X shape with lope at the top. Make sure that the ends are the same size at the bottom.
Step 7:
Take the center of the loop and pull it to the middle of the X.
Step 8: Scrunch the Bow
Start at the bottom of the X holding all the pieces tight and scrunch it together accordion style making the shape of your bow.
Step 9: Keeping the Shape
Take your wire or string and wrap it securely around the middle of your bow to make sure it stays together.
Step 10: Preparing Your Clip
Take the 3/4 inch ribbon sliding one piece in the center and wrapping it to the back and hot glue it to the clip.
Step 11: Adding the Middle of the Bow
Take your piece of bling and wrap it around the center of the bow covering your string/wire and hot glue it onto the bow in the back. If you choose to add just ribbon in the center tie a small knot in the center of an appx 3 inch long piece of ribbon. Place the knot in the center of your ribbon and hot glue it together on the back of the bow.
Step 12: Adding the Clip/ponytail Holder
Find the center of the back of your bow. Now hot glue your clip to the back of your clip to the bow. Make sure it is secured very well. If you decide to use a ponytail holder you will add it before your center piece and hot glue it down all together.
