Introduction: Bowline Knot
The Bowline knot is a rescue knot. If you are ever stuck in a hole or something and someone comes to rescue you, If they throw you a rope and tell you to hold on while they pull you up, you should tie the bowline knot. Can be used on a pole for practice, ect..
Step 1: Supplies
All you need is a rope.
Step 2: Wrap It Around Your Body
First you wrap the rope around your waist once.
Step 3: Make a Loop
Make a loop with either side.
Step 4: Push the Rope Through the Loop
Push the rope on the other side through the loop.
Step 5: Go Around the Rope and Back In.
Put the rope (the side that went through the loop) around the loose end of the rope with the loop. Then put it back through the loop.
Step 6: Pull It Tight
Pull the rope tight.
