Introduction: Box Project
Learn basic tools to create a Box with Comb Joints
Step 1: First Panel
Open a new document and Selct the Top Down view
Change the view to Orthoganal
Drag a BOX shape from the toolbar onto the workplane
Step 2: Resize
Click on the squares around the edges of the box and adjust the size to 60 x 60mm
Step 3: Creating a Comb Joint
Drag a TRANSPARENT BOX onto the workplane
Adjust the width to be 6mm - length can stay the same
Move the box to be aligned with the top corner of the main cube
Drag the transparent cube 3mm into the main cube
Drag the transparent cube 9mm vertically
Step 4: Create More Combs
You can select the transparent cube and copy and paste it
Drag these copies so that they are 6mm away from each other (you can count the squares or look at the measurement shown on the screen)
Repeat this until you have 4x transparent cubes
Step 5: Complete the Comb All the Way Around
Select all 4 and then copy them again, dragging them to the other side
Make sure they are 3mm away from the edge
Repeat the copy process again, but this time rotate the copies 90degrees and align 3mm away from the top edge
Remember - they must be 9mm away from the edge!
Step 6: Finish the Comb Joint
Copy the top transparent cubes one last time and drag them down so that they are 3mm inside the base line.
Select all the objects and click on the GROUP icon
The transparent cubes now become holes and cut the main box
Step 7: Creating the Other Panels
Return to the TOP view and return to Orthagraphic mode
Drag another cube into the workspace and make sure this is 60x 60mm as well
Align it so it overlaps the inner line of the first panel
Click on the first panel and then on the lightbulb icon to hide it
Step 8: 2nd Panel Comb Joint
To align the model you will need to make sure that no panels overlap each other.
Therefore, you will need to cut out the areas that Panel 1 has as a "comb"
Drag a Transparent Cube into the workspace and make it 6mm thick
Align it with the top corner then drag it 9mm Left (into the cube) and 3mm vertically down away from the edge
Create a copy and drag this 3mm away but also drag it out (right) by 3mm
Copy this again 4 more times making sure they are all 6mm from the edge
Step 9: Create the Other Side
Select all the Transparent boxes and Copy and Paste them
Drag them to the other side
Align the top one so that is 9mm inside the main panel and 3mm away from the top edge
Select all the remaining boxes and drag them so that they are 3mm inside the panel and aligned with the bottom edge
Step 10: Creating the Base Comb
Select a Transparent Box and rotate it 90 degrees
Align it with the top cutouts and make sure it is 6mm apart from the inside edge
Copy and Paste 2x further copies making sure these are also 6mm apart
Step 11: Grouping the Objects
Select all the objects and Group together - cutting out the combs as a result
Click the Lightbulb icon and the original panel should appear - you should notice all your comb fingers and cutouts lining up.
If there are any changes required select the new panel and then select UNGROUP
This will bring back the Transparent Boxes and you can adjust as needed
Step 12: Create the Left and Right Panels
Drag a box object into the workspace
Make it 60 x 60mm and align it to the inner edge of the base panel
Hide Panels 1 and 2 using the Lightbulb icon
Step 13: Create the Comb Joints
Drag a transparent box into the workspace and make it 3mm thick
Align it with the bottom corner of the panel
Drag it so that it is 9mm inside the panel
Copy and Paste this box, Align this with the edge and then move it in by 3mm inside the panel
Drag another Transparent Box into the workspace and make this 6mm wide
Align this with the edge and then drag it in by 3mm
Copy and Paste this a further 3x
Note your transparent boxes should align with the top edge
Step 14: Copy and Mirror for the Other Side
Select all your Transparent boxes
Copy and Move them to the other side of the panel
Select the Mirror Tool and then click the Down/Up arrow to mirror the selection and then drag these in place
The 4x 6mm cutouts should be 3mm away from the edge
The thinner sections should be 9mm and 6mm away from the edge
Step 15: Right Hand Side
Copy the 6mm Transparent Boxes and move to the right hand side
Rotate and then move so that is 3mm inside the panel and 6mm away from the lowest cutout
Copy and paste this 2x times
Select all objects and Group
Bring back all objects to check the alignment
Step 16: Mirror the Side Panel
Show all components
Select Panel 3 and copy and paste it moving it to the other side of Panel 1
Make sure to align it to the inner most edge
Use the mirror tool to flip it and check alignment
Repeat with Panel 2
Step 17: Adjusting the Height of the Panels
Move to Perspective view and rotate the camera to see the edges of the boxes
Select all the panels
Click the central box under the UP arrow
Change the height to 3mm
Step 18: Assemble the Box
Select a Panel
Use the Rotate arrow along the edge to rotate the panel by 90degrees - so it is now upright
Move the Panel so it fits in the slots
Note: You can change views, rotate around, Zoom in and use the rounded triangle arrows to move the panel. The closer you zoom, the more accurate it will be
Repeat for all panels
Take a screenshot and add it to your workbook
