Introduction: Box for Airbrush / Caja Para Aerografo
Hello everyone! As I already mentioned in other instructables, I'm a super fan of modeling, wow, it's my main hobby, and well, the fact is that the other day while I was painting with the airbrush, I went to change the cup and I went crazy opening drawers and looking in places more diverse until I found her, that is how this project was born.
I have done it entirely with Tinkercad, I have got the hang of it to make mdf furniture and... I would say that they are quite cool. If anyone finds it interesting, you could make an instructables on how do it.
Broadly speaking, it is a box to store the airbrush, cleaning objects, needles, rubber, parts and spare parts... In one place. I know that many airbrushes bring their own case, but only the airbrush fits there and not everything that accumulates over time. I leave a video of the project to see if you dare to do it!
Hola a todos! Como ya comente en otros instructables soy super fan del modelismo, vaya es mi hobby principal, y bueno, el caso es que el otro día mientras pintaba con el aerógrafo, fui a cambiar la copa y me volví loco abriendo cajones y buscando en los sitios mas variopintos hasta que di con ella, es así como nació este proyecto.
Lo he realizado con Tinkercad íntegramente, le tengo pillado el tranquillo para hacer muebles de mdf y ... diría que quedan bastante chulos. Si alguno lo ve interesante, podría realizar un instructables sobre eso.
A grandes rasgos es una caja donde guardar el aerógrafo, los objetos de limpieza, las agujas, la goma, partes y repuestos... En un mismo sitio. Se que muchos aerógrafos traen su propio estuche, pero ahí solo cabe el aerógrafo y no todo lo que se acumula con el tiempo. Dejo un video del proyecto para ver si os animáis a hacerlo!
Basically you will need a CNC, 3mm white mdf and white glue. This project can also be cut with a laser, but you will have to check the two pieces that go in the guides to change the thickness, since with the laser you will not be able to make the recesses.
Básicamente necesitaras un CNC, mdf de 3mm blanco y cola blanca. Este proyecto es posible cortarlo con laser también, pero tendrás que revisar las dos piezas que van en las guías para cambiarle el grosor, ya que con el laser no podrás hacer los rebajes.
Step 1: Design / Diseño
The box consists of a holder for the airbrush that is stored under a hatch on the side. Two small drawers to store cleaning supplies, one of them and the other, two slots for needles and an auxiliary tray. Finally a large drawer where you can easily store the air hose.
I leave the link to the project in tinkercad in case someone wants to make the modifications to their liking or just take a look. Here the link.
La caja se compone de un soporte para el aerógrafo que se guarda bajo una compuerta en el lateral. Dos cajones pequeños para guardar útiles de limpieza uno de ellos y el otro, dos ranuras para agujas y una bandeja auxiliar. Por ultimo un cajón grande donde se puede guardar la manguera de aire fácilmente.
Dejo el enlace a el proyecto en tinkercad por si alguien quiere realizar las modificaciones a su gusto o simplemente echar un ojo. Aquí el enlace.
Step 2: Box / Caja
In order not to put the whole list of parts in the same step, I am going to divide it into several topics to make it more enjoyable. As you will see, the assembly tutorial, I have also done with tinkercad, a picture is better than a thousand words.
Be careful, do not stick the sliding side!
Para no poner todo el listado de piezas en el mismo paso, voy a dividirlo en varios temas para que sea mas ameno. como veréis, el tutorial del montaje, lo he realizado también con tinkercad, mas vale una imagen que mil palabras.
Ojo, no pegues el lado deslizante!
Step 3: Drawers / Cajones
I've added an "X" for the number of copies of each object, since not all parts are one of each.
He añadido un "X" para el numero de copias de cada objeto, ya que no todas las partes son una de cada.
Step 4: Airbrush Stand / Soporte Aerografo
Pay attention to the sliding side!
Presta atención a el lado deslizante.
Step 5: Finish / Fin
Assemble all the previous pieces, fill it with your favorite tools and enjoy!
I hope you liked it and you are encouraged to do it. If you have any questions, suggestions or confusion, do not hesitate to leave your comment, I will be happy to help you. Don't forget to follow me on instagram @modelkitsdeluxe for more kits and work in progress!!
I have carefully reviewed the project and I have done it as I propose it in this intructable so that you do not have problems when doing it yourself and do not waste your time, however, if you see something strange, I appreciate your collaboration.
Lastly, I'm sorry if something strange slipped into my translations, I always check them, but it can happen.
Monta todas las piezas anteriores, rellénalo con tus herramientas favoritas y a disfrutar!
Espero que os haya gustado y os animéis a hacerlo. Si tenéis alguna duda, sugerencia o confusión, no dudéis en dejar vuestro comentario, estaré encantado en ayudaros. No dejéis de seguirme en instagram @modelkitsdeluxe para mas cacharros y trabajos en curso!!
He revisado cuidadosamente el proyecto y lo he realizado tal cual lo propongo en este intructable para que no tengas problemas a la hora de realizarlo tu y no malgastes tu tiempo, no obstante, si veis algo extraño, agradezco vuestra colaboración.
Por ultimo, lamento si alguna cosa rara se me coló en las traducciones, siempre las reviso pero, puede pasar.
CNC and 3D Printing Contest
