Introduction: Bracket Model on Autodesk Inventor
Step by step on how to model a bracket in Autodesk Inventor.
Step 1: Open Autodesk Inventor
Open your Autodesk Inventor application on your laptop. It should look something like the logo presented above.
Step 2: Create a New File
When your application has fully loaded, click file -> new -> standard (in.)-> create.
Step 3: Start Your First Sketch
Click the "Start 2D Sketch" button in the top left corner of your screen. After clicking this your screen should look somewhat like the one shown above.
Step 4: Select the XZ Plane
Select the XZ plane. You can select this by moving your cursor to the left side of your screen, hitting thew down arrow on the "origin" tab, and selecting the XZ plane (as shown above). Or, you can select the XZ plane on the drawing in the center of your screen.
Step 5: Adding Dimensions and a Rectangle
By selecting the rectangle option from the ribbon at the top of your screen, you can draw a rectangle that is aligned with the centerline, as shown above. Add the 2 dimensions shown by selecting the "dimensions" tab in the ribbon.
Step 6: Extrude the Sketch
When you have finished adding dimensions, click "Finish Sketch" and then click "extrude". Change the height of the extrusion to 10 in. Then hit "ok"
Step 7: Start a New Sketch
click "Start 2D Sketch" again. Then select the top surface of the shape you just created. Then add the following shapes and dimensions.
Step 8: Add Fillets
After finishing the sketch, use the fillet tool to create two fillets on the corners shown in the picture.
Step 9: Start Next Sketch
Select "Create 2D Sketch" again. Select the bottom of the surface. Draw out the shape shown above. Use the tangent tool to attach the circle to the lines. Make sure to connect all the lines to create a closed shape.
Step 10: Trim the Circle
Use the trim tool to trim the side of the circle on the inside of the sketch.
Step 11: Extrude the Shape
Use the extrude tool again. Keep the length at 10 in. Press ok.
Step 12: Create a New Sketch
Create a new sketch using the "Start 2D Sketch" button again. Draw a circle
Step 13: Add Dimensions and Constraints
Add a concentric constraint to the new circle connected to the rounded edge. Add the dimension shown in the picture above.
Step 14: Extrude Cut New Circle
Use the cut command on the extrude tab to cut a circle into the shape.
Step 15: Create Sketch on XY Plane
Use the origin drop-down on the left of the screen to select the XY plane after selecting "Start 2D Sketch".
Step 16: Draw New Sketch
Draw this triangle sketch in the new 2D sketch.
Step 17: Extrude Sketch
Use the extrude tool to create a 15-inch shape. Use the symmetric option to center the shape.
Step 18: One Last Sketch
Create one last sketch on the back of the shape. Draw a circle and use the concentric constraint to align it with the rounded edge. Use the equal tool to make the new circle the same dimension as the original.
Step 19: Extrude Last Sketch
Extrude the last sketch outwards after finishing the sketch. Extrude 2 inches.
Step 20: Save Bracket
Save the bracket file using the save icon at the top left of the screen.
