Brake Lights for Bikes
Intro: Brake Lights for Bikes
This is a really easy weekend project that you can do to give your bike some brake lights.
STEP 1: Get Your Parts
Get the parts that are needed:
Lots of Zip-ties
Wire
Copper (I used some 14 gauge Romex I had around my house)
Tail light (I used a Planet Bike Blinky 3 that I have been using for years on my bike)
Soldering Iron
Solder
Bike
STEP 2: Take Your Stuff Apart
Take apart your tail light. We are needing inside in order to rewire it to work with your brakes.
STEP 3: Bend Switches for Your Brakes
Take your Romex and bend it into a switch that you can zip-tie to your brakes. Solder one end of your wire to the end of your Romex.
STEP 4: Zip-Tie Your Switches to Your Bike
Take your newly soldered switches and zip-tie it to your bike. I have disc brakes on my bike, if you have a different style of breaks I'm sure that a quick re-work will suffice.
STEP 5: Re-wire the Tail Light
Take the battery connector closest to the power button (we are going to be running our wires through here later) and cut it in the middle. This is where we are going to add our wires from our switches.
STEP 6: Zip-Tie Everything Up and Attach It to Your Bike
Zip-tie your wires to your break lines and make sure to leave enough room that you can turn your handlebars right and left without it catching on your wires. Test it out and make sure that everything is working as it should.
20 Comments
David-KiyoB 3 years ago
to hydraulic brakes for motor it off. Add magnet to lever and relay to body so touching or very close.
RyanD46 8 years ago
Does this get grounded when exposed to water( e.g. riding in the rain)?. Thanks.
tomatoskins 8 years ago
I haven't had any issues with mine at all. As long as water doesn't get in the light at all, you should be more than fine.
pravin gadher 8 years ago
Yonatan24 8 years ago
The problem is that when people see that the (brake) light is on, they don't know you're stopping...
Very true. But it comes in handy when you are riding with your buddies and they know what it means.
zubaer 8 years ago
Can u post a video, i really in need of that :'(
shivam kale 9 years ago
jkoyne 9 years ago
ragoldsmith 9 years ago
This is awesome and simple, how are there no comments? If you tap your brakes twice and hold, does the light start blinking? :)
cdmselector 10 years ago
That is a cool idea. Will do it in few days but wont fixing it at the brake handles be a much more better? I mean, will omit the unnecessary extended wiring. Especially down the fork.
But good job!
Joceyvdv 10 years ago
JillWood123 10 years ago
samrianv 10 years ago
tomatoskins 10 years ago
Yard Sale Dale 10 years ago
mikecraghead 10 years ago
madushan92 10 years ago
vicesat 10 years ago
