Introduction: Brass Plaques With Electro Etching
Here's an easy method for etching metal with electricity. It could be you want to etch your own circuit boards, or in my case, I'm making brass plaques to commemorate my brother, who recently passed away. Other methods use toxic etchant chemicals, but this method uses salt water. Both methods have pros and cons, but I prefer the electric method because it's safer and the cleanup is more straightforward.
Here's what you'll need:
- 12V 2A power supply
- Extra long wires
- Gator clip
- Brass to etch
- Steel to match approximate brass size
- Plastic container larger than your metal
- Warm water
- Salt
- Aquarium pump with tubing
- Aerator stone
- Laser printer and iron/laminator/heat press (for toner transfer method) or Vinyl cutter and adhesive vinyl (for vinyl method)
- Electrical tape
Thanks to Digi-Key for sponsoring this project! Check out this project on Maker.io.
Step 1: Video
Watch the video for this project to see the etching in action.
Step 2: Create Artwork
I designed the artwork in Illustrator to mimic the Cafe Bustelo logo-- really I only needed to make up an R and an N, since I could just trace the rest of the letters.
Step 3: Art Transfer (Toner Transfer Method)
Step 4: Art Transfer (Vinyl Cutter Method)
Before you etch, you'll need to get your artwork transferred onto the brass, masking out everything you don't want to etch. There are a few methods for this step, as well. I first tried the toner transfer method of ironing on a laser print-out, then soaking off the paper in water, but I couldn't get the temperature and pressure worked out well enough to successfully transfer my image. So instead I used my vinyl cutter to make a sticker of my design and stuck it to the brass.
Step 5: Attach Positive Wire
On the back of the brass, tape the stripped end of the positive wire so it makes good contact. Cover the entire surface of the brass with more sticky vinyl or another waterproof tape, except where you want to etch.
Step 6: Set Up Etching Bath
Attach a gator clip to your negative wire, and clip it to a piece of steel about the same size as your brass. Now that your two electrodes are ready to go, set up your plastic container filled with warm, salty water, and containing an aquarium aerator.
Place the metal electrodes into the solution, one on either side of the aerator. The two electrodes should not touch. You can use a clamp to hold one or both to the side of the container.
Now plug in the aquarium pump and the 12V power supply. You should see bubbles start to form on the metal surfaces. I let each of my plaques etch for about two hours.
Step 7: Science of Electrolysis
What's happening here? It's a type of forced corrosion. The positively charged plate excites the electrons in the copper and zinc making up the brass, and some of the atoms give up their outer shell electrons to the surface atoms, which are then called positively charged ions. They dissolve in the liquid electrolyte, breaking off from the surface. Eventually, you can start to see the build-up of copper in the solution.
Step 8: Finishing
I applied some Brass Black metal finish to the etched sections before removing the vinyl mask.
I cut out the smaller plaques with my jeweler's saw and cleaned them up with my belt sander before drilling the mounting holes. Then I used rivets to attach one to the coffee can, my brother's preferred vessel.
Step 9: Complete
To keep up with what I’m working on, follow me on YouTube, Instagram, Twitter, Pinterest, and subscribe to my newsletter. As an Amazon Associate I earn from qualifying purchases you make using my affiliate links.
