Introduction: Bread Board
About: I am a self taught carpenter. I started carpentry in 2010. I have learned finish carpentry and on-site installations. I am also self taught on Auto CAD and Adobe Illustrator which I use for woodwork designs. I…
Fun bread or cheese board.
Laser Machine (for the shape and engraving on top)
1/4 Wood (for my own bread board, I used poplar wood)
Glue
Sander and sand paper
Food grade oil
Rag
Step 1: Laser Work
If you have a laser engraver, you can engrave an image onto the surface of your project. If you don't, you can still make a bread/cheese board.
I also used the laser engraver to cut the shape out of wood. I made a top piece and a bottom piece. However this can also be done by hand, with only one board if wanted.
Step 2: Sanding
After cutting it, I glued the two pieces together, keeping all sides flush.
I then sanded the board with 150 grit sand paper, 220 and then 320. This gave me a smooth feeling board.
Step 3: Oiling
I then oiled the board using a cutting board oil (food grade) and followed the instructions on the bottle.
Step 4: Completion
I then decided to put a leather strap through the hole in the top of the board so that I can hang it in the kitchen
