Introduction: Bride Garter
Material List
Elastic Band 1.5 cm, 50cm
Soft Macramè band 4cm, 100cm
2 Blue Satin Tape 1cm, 60cm + 30 cm
white and blue cotton spool
Sewing Machine
Needles and pins
any textile materials store
any emporium near your home
amazon
Step 1: Assemble Macramè Base
Take the macramè tape and cut to half its length, than overlap the straight sides of two parts obtained leaving out the wavy side and sew them together with your sewing machine (use white cotton spool)
Step 2: Overlap Blue Satin Ribbon
Put the Blue Satin Ribbon at the center of macrame band sewed at previous step, change cotton spool for your machine (from white of previous step to blue), guide with your hand the two bands to remain overlapped during your sewing operations
Step 3: Some Fold
At this point on band obtained make a fold and sew it every 5-6 cm along the entire length of the band leaving about 3 cm at two ends of band (to have space to close the band)
Step 4: Elastic Band
Now we need to put elastic band on our garnet, put the elastic band on your sewing machine overlap macrame band with blue ribbon up and sew them together (keep elastic band slightly tighter than macramé band)
Blue ribbon covers the elastic band, so elastic band will not be visible at the end of you work
Step 5: Close Ends of Garnet
As you see in video close the two ends with upright facing inward, match exactly all parts of two ends and sew together them, with 30 cm of blue satin ribbon make a bow handmade, hand sew the center of the bow (with a hidden stitch), put it on the center of garnet with another hidden stitch (handmade)
Step 6: Tips
You can modify as you want, adding more bow also of different dimension, adding dot light with swarovski or pearl, with different dimension you can follow same step to obtain wristband
