Brief G-Shock Bezel Stealthing Guide
Intro: Brief G-Shock Bezel Stealthing Guide
Here is a very simple, stealthing project. I am planning to do a lot more to my little DW-5600 like reverse the display, stealth the faceplate (if possible), but for now I wanted to stealth the bezel (remove the white paint).
STEP 1: Equipment Needed
The first step was to gather all the necessary equipment. For me that means Goof Off (not Goo Gone or any similar sounding products), a small ceramic bowl/dish (plastic ones may melt with the Goof Off inside it) this is one I made myself, a small pair of tweezers, and an old toothbrush or scrubbing brush.
STEP 2: Remove the Bezel for Paint Stripping
I removed the bezel from my DW-5600 and poured just enough of the Goof Off into the bottom of the bowl to cover the bottom. I place the bezel in the bowl face down so that the lettering was constantly submerged. Doing it this way saves using a lot of unnecessary Goof Off. I set my count down timer (CDT) for 20 minutes and stuck the bowl outside to avoid the nasty smell/fumes.
STEP 3: Clean Up and Reassembly
Beep, beep! Ok 20 minutes is up and I lift out the bezel using the tweezers. I take the toothbrush and dip it into the Goof Off and 'gently' scrub the lettering off the bezel. The paint just washes off and doesn't take very much effort with the toothbrush. Then I wash the bezel in warm soapy water to remove any chemicals and dry it off. After a quick reassembly the bezel is looking nice and stealthy.
Next will be for me to work on changing the polarizing film to make the display negative. Then I am thinking of ways I can black out all of the faceplate lettering... fun and games.
Not a lot of pictures here, but hopefully enough get a feel for how this works. The same process can be used for removing lettering or paint on resin straps. Happy stealthing!
25 Comments
men3 6 years ago
Hello, I have a problem with a G-SHOCK Model. The Model is the G8900A-1.
I purchased this model several years ago, based on the pics I saw online of the watches large dial - which I loved. Unfortunately after opening the box, I was very disappointed that both the back strap, and bezel were seriously GLOSSY!
To me this made the watch look cheap, as well as something for a child, or a teenager! I HATE the glossy finish, and have barely worn the watch since.
I had considered removing both the bezel, and the strap, to apply some sort of chemical(?) in the hope of stripping off that glossy finish. Though if I could just find a proper replacement bezel, and strap in a dull, black, matte finish instead - that would be awesome!!!
I hope someone here will see this, and have offer a solution for me.
Thank you for reading.
All the Best, DOC ; )-
ragls 8 years ago
HIthanks for thepost, as well as removingthe lettering does the goof off have any effect on the bezel? was the bezel shiny previous to goof off and now a matt finish ? or does it not make a difference. My Bezel is already matt
mfluharty2 10 years ago
is goof off acetone? perhaps you could try nail polish remover in a glass dish to help stealthiness of your watch. Acetone will dissolve ABS plastics too. You are genious!
dpiloyan 11 years ago
Jeru 12 years ago
Hey, Thank you for your great post. We don't have Goof-off here (Amsterdam, The Netherlands) but I can order it of eBay. I was wondering: can't I just put my entire 20BAR resistant G-7710 in Goof-off? (To take off all the yellow.) Do you use tweakers cause it's too agressive to make contact with?
bfgreen 12 years ago
If you are referring to the G-Shock that is totally yellow, I don't think the color can be removed. I believe the yellow color is throughout the plastic. If it just has a lot of extra yellow paint for lettering you might be able to make it work. Either way, disassemble the casing and strap and only submerge them in whatever chemical you choose to use.
Methylated spirits, denatured alcohol, or some form of safe paint stripper or paint thinner would be the closest product to Goof-Off that I can think of. Hope this helps. Post an update on how it goes!
Jeru 12 years ago
Problem is that I really don't know how to disassemble the rubber ring and the light button; it's totally different than the G-Shock you used in your guide.
Jeru 11 years ago
Kind regards from Amsterdam
Jeru 12 years ago
limonchi 13 years ago
biffula 12 years ago
I would recommend replacing the battery soon though. Even if it's not run out, they have a finite life expectancy and you wouldn't want the battery to fail and start corroding the inside of you watch.
Treat your G to a new battery soon and give it another 20 years of happy living :-)
limonchi 12 years ago
i will look for the customer service email in spain
thanks
chosenangelx 13 years ago
In fact, I made another instructable about how to dye a resin strap another (darker) color. One of my G-shock Mudmans came with a dark green case and band as standard. It's the Mudman with the negative display. In all the pictures I saw of it the band and casing was so dark it looked black, but wasn't when I received it.
Well the plastic resin used to make the casing and strap is actually porous and if you removed them and place them into boiling water with black Rit dye you can dye the entire plastic components a darker color (you can't lighten them).
I did that and now have a negative display mudman with all black casing and strap - it looks super stealthy.
CaseyCase 15 years ago
mastermakoko 13 years ago
