Introduction: Bring Nature to Life: Easy Make a Mallow Flower Bracelet
The Mallow Flower Bracelet, is inspired by the gentle elegance of the mallow flower, a bloom known for its delicate petals and calming colors.
Water Drop-shaped Beads: 200 (Pink, Blue, White or Orange)
Durable Thread: 30cm
Scissors and pliers
Step 1: Position the Beads
Threading a positioning bead and an end cap onto your thread, using two needles (black thread is for visibility, but white is recommended for aesthetics). You can also use one needle to secure the top of your design, helping to maintain its structure as you begin beading.
Step 2: Make the First Flower
- Secure the Top: You can use one needle to hold the top of your design in place.
- Create the First Flower: Cross the two needles through a drop bead, then thread seven more beads onto one needle. Use the other needle to go back through the first drop bead, forming a petal circle.
- Add the Flower Center: Next, thread both needles through a cat's eye bead, which will serve as the center of the flower.
- Secure the Flower: Cross the threads back through the beads below to ensure everything is secure. You can do this a few times for added stability.
- Attach the Leaves: Finally, thread two green beads onto the ends of your thread to represent leaves, adding a charming touch to your flower design.
Step 3: Create the Second Flower
Repeat the previous steps by crossing the needles through another drop bead to start. Determine how many flowers to make based on your wrist size.
Step 4: Adding the Extender Chain
Attach the extender chain using a jump ring for adjustable sizing.
Step 5: Attach the Lobster Clasp
Securely connect the lobster clasp using a jump ring for a reliable closure.
Step 6: Add a Decorative Flower
If you want to embellish your bracelet further, thread on another positioning bead and repeat the flower-making process. This additional flower will make your bracelet even more special and unique.
Step 7: Done!
Looking forward to seeing your finished piece with us!
