Introduction: Bring New Life to an Old Garden Bench – DIY Step-by-Step Restoration
When we moved into our new house a few years ago, the previous owner left an old garden bench in the backyard. It's falling apart, the metal is rusty, and some parts are missing. But instead of tossing it away, I saw potential for a makeover to bring it back to life.
Tool list:
Step 1: Planning: Understanding the Structure
The bench is made up of two parts: the metal on the 2 sides and the main section, which consists of several pieces of lumber. I plan to keep the metal parts clean and restore them, as well as replace the panel sections with new lumber since the old ones are rotten.
Step 2: Disassembly: Taking Apart the Old Bench
Remove the nuts and bolts or screws if possible. In my case, the bolts and nuts were so rusty that I stripped the heads. With no other option, I had to use an angle grinder to cut through the nuts.
Step 3: Cleaning: Restoring the Parts
- Use a metal brush and soap water to scrub the rust off the metal parts.
- (optional) Use a power washer to thoroughly clean the parts.
- Let it dry
Step 4: Painting: a Fresh Coat of Color
Apply a fresh coat using spray paint. Be sure to wear a mask to avoid inhaling fumes. To prevent overspray, either work in an outdoor area or use a box to contain the paint.
Step 5: Rebuilding the Main Body: Cutting the Lumber
I used 2x4 lumber for this project:
- Cut it to the desired length.
- Rip it to the desired width.
- Rip it to the desired depth.
Next, test if the cut lumber fits between the two metal side pieces. If it doesn't fit, you may need to rip the lumber thinner.
I then used a trim router to round the sharp edges and an orbital sander to smooth the rough surfaces. Finally, I applied a coat of stain and sealer to the lumber, followed by an extra layer of polyurethane to ensure it's fully weatherproof.
Step 6: Assembly: Bringing It All Together
Assembling everything is relatively easy. Just use the appropriate size screws (or bolts & nuts) to fasten the lumber to the two metal parts, and you're done.
Step 7: Final Reveal: the Finished Bench
That wraps up this guide. Thanks for following along! If you're interested in how we transformed our front yard from grass to a beautiful vegetable garden, be sure to check out this Instructable. I'll see you in the next one.
