Introduction: Bristle Bot II - From a Cheap Electric Toothbrush
Yet another bristle bot, this one from a discounted electric toothbrush. I now know why it was on sale, because it did not work out of the box. But that's OK, is for fun, no?
Step 1: Dissassemble!
umm, cut the head off the toothbrush
umm, rip the guts out.
Sorry to be a bit terse, but that's what I did. Perhaps a bit more detail could help. The head of the toothbrush is cut off with a pair of wire cutters. The guts of the toothbrush were extracted. A pair of needle nose pliers was used, but it could be done with most any pointy object on hand. This toothbrush was cheap, very cheap. Did I mention it did not function out of the box? And yes, the battery was good, 1.6V.
Step 2: Soldering
The batteries and motor are attached to the toothbrush with a hot glue gun. Try to keep all balanced and aligned symmetrically.
I did change from the 1 fresh battery which came with the toothbrush to 2 nearly dead batteries, about 1.3V each. Two batteries gives a bit more juice, of course, but also makes a symmetrical, balanced assembly.
Step 3: Changing a "spring" Into a "Switch:
the spring is reinforced by usubg hot glue to better attach it to the motor, as the copper lead coming out of the motor is quite flimsy.
Then, use a pair of pliers to contort the spring such that it tends to press against the end of the battery. The bot should now hum away happily, and proceed to terrorize cats and other household fauna. A simple piece of paper breaks the connection.
I have a brief video, but You tube is down tonight. TBD.
This one goes faster than expected, but tends to spin. I trmmed some of the bristles, changing the behavior. You mileage may vary.
Have fun!
Have fun!
