Introduction: Broken Phone Fix (silly Solutions)
To create the project, you must use tinker cad.
Here is the link to the screen image used: https://wallperio.com/data/out/454/screen-wallpape...
Video link:
Step 1: Start
Start by creating a cube that is (39.38 X 19.35)
Step 2: Edge
Create a cube that is (28.28 X 28.28)
Put the cube to an edge and angle it 45 degrees
Step 3: Edge
Set the cube to a hole
Select both blocks and group them to create the round edge of the phone
Step 4: Base
Duplicate and rotate the block
Step 5: Base Done
Duplicate the two blocks and rotate them to create the base of the phone
Group them and set the color to black
Step 6: Bezel
Duplicate the phone and size it down
Set it to hole and group the two
This is to create the bezel
Step 7: Image Gen
Get the image generator
Set the color to blue/cyan/turquoise
Step 8: Screen
Use the broken screen image as the base
Set the smoothness to your liking
Step 9: Screen
Create the notch by duplicating the original base layers (2 of them)
Shorten them and set the color to black
Place a notch on the screen in the optimal location
Step 10: Screen
Set the notch to hole
This is to prevent the textures of the screen from clipping thorugh
Step 11: Screen
Group both items
Step 12: Screen
Place the screen down
Step 13: Screen End
Duplicate the notch and return it to the same place (where the hole is)
Step 14: Tape
Create a cube that is (71.91 X 29.92)
This is the base of the tape
Step 15: Tape
Create a triangle that is (4.92 X 6.02 )
We will have 8 in total (4 on each side)
Step 16: Final Touches
Move the tape over the phone
And voila, it's done
