Broken Snow Shovel Scoop Replacement
Intro: Broken Snow Shovel Scoop Replacement
This last winter broken snow shovels starting appearing everywhere. I tried to track down replacement parts, but it turns out that replacement scoops don't seem to exist. So I set about to make a simple replacement scoop using basic tools and found materials.
STEP 1: Tools
To create the scoop I used a clamp, wrench, vise-grips, hammer, drill (& bit).
STEP 2: Materials
I was lucky enough to find some scrap metal from a local source. When looking, make sure you find something you'll be able to shape later with the vise-grips and hammer. You'll also need some hardware - nuts & bolts - to attach the scoop.
STEP 3: Edges
I folded over the top and side edges of the scoop to add strength and a smoother surface. Use the vise grip to bend up the edge, then hammer it down flat.
STEP 4: Shape the Scoop
To give the scoop shape, I folded the metal around the handle, then hammered out the lower section to leave a flat blade.
STEP 5: Handle Holder
I used a section of hallow metal pipe to secure the wooden shovel handle to the new scoop. I hammered down the end, then clamped it in place.
STEP 6: Drill and Bolt
With the pipe secured in place with the clamp, I put the handle in and drilled holes for the bolts. Using the wrench, I bolted the handle, rod, and scoop together.
STEP 7: Completed Shovel
The shovel completed and ready for next winter.
11 Comments
SpikeF1 5 years ago
The Volkemon 17 years ago
philorr 17 years ago
adamvan2000 15 years ago
Phil B 15 years ago
_diyMATT 17 years ago
gover57 17 years ago
StepsoftheSun 17 years ago
HamO 17 years ago
clydicus 17 years ago
