Introduction: Broom Racks From TechShop
Purpose: organize your tools
Tools: table saw, band saw, router, drill press, orbital sander, hand drill, level
Materials: 3/4” plywood, 1/2” all thread bolts / nuts / washers, wall anchors, sand paper
Step 1: Cut Wood
Cut the plywood down to 24” x 8” on the table saw. If you are starting with a full sheet, the panel saw might be useful too. Next, trim the corners to 45º on the band saw. A second piece of plywood 22” x 2” will be needed as well.
Step 2: Holes
Drill the four bolt holes with the drill press (a hand drill is not recommended as it will be difficult to ensure perpendicular hooks – and you don't want things sliding off!). Since the bolts require nuts on the backside, the second piece of plywood will bring the face plate off the wall. Use a paddle bit to countersink the backside and provide necessary clearance.
Dimensions are noted in the third image.
Step 3: Assembly
Attach the bolt / nut / washer combo platter. Finger tight should be adequate for this situation and keeping all of the bolt heads horizontal will give a cleaner, more professional look. Mount 67” off the ground with wall zip anchors and clean up your clutter!
Congratulations, your new nickname is officially “Sweepy”.
For more resources, tools, and training, head over to TechShop!
0101001101101111001000000111010001101000011001010010
00000110110101101111011101000110100101101111011011100
0100000011010010111001100100000011100000110000101110
0110111001101100101011001000010111000100000010101000
1101000011001010010000001101010011000010110111001101
0010111010001101111011100100010011101110011001000000
1101110011001010111011100100000011011100110100101100
0110110101101101110011000010110110101100101001000000
1110111011010010110110001101100001000000110001001100
101001000000010001001010011011101110110010101100101
01110000011110010010001000101110
