Introduction: Bubble Bath That Never Runs Out of Bubbles
Everyone loves bubble baths. But sadly, they can only last for so long. Eventually the bubbles pop and you are left with just an ordinary bath with no bubbles.
So I decided to make a bubble bath setup that would continuously replenish the bubbles so that they would never run out. That way you can enjoy a bubble bath for as long as you want.
Step 1: Materials
These are the materials that you will need to complete this project. They can all be purchased at most pet supply stores. They will be located with the aquarium supplies.
Aquarium Air Pump - Air pumps come in a variety of sizes and are usually rated based on the size of the fish tank (in gallons) that they are able to aerate. The larger the air pump, the more bubbles it will be able to create. Larger pumps tend to have multiple output nozzles where you can attach multiple air tubes and air stones.
Aquarium Air Tubing - This is standard plastic tubing and is usually clear. This is typically sold as a single long piece of tubing. You may wish to cut it to a length that is more convenient to work with.
Aquarium Air Stone - These are small artificial stones with tiny holes that disperse the air as small bubbles. They come in a variety of shapes and sizes. They are also rated based on the size of the bubbles that they make. Standard air stones will make moderate sized bubbles. Whereas "fine" and "mist" stones will make smaller bubbles. In this application, smaller bubbles will last longer, but larger bubbles will build up a larger foam. So I chose to use a standard air stone.
Bathtub of Soapy Water - Just take a bathtub and fill it with water. Pour in your favorite bubble bath soap as the water is running to get the best mixing.
Step 2: Connect the Air Pump, Tubing and Air Stones
The first thing that you need to do is connect the air pump, air tubing and the air stones. This should be pretty straight forward. Push the end of the air tubing onto the output nozzle of the air pump. Then push the nozzle of the air stone onto the other end of the tubing. If your air pump has multiple outputs, you can repeat this to set up multiple hoses and air stones.
Step 3: Test the Air Stones
Once all the parts are connected, you are ready to test your air stones. When you turn on the air pump, you should be able to hear air hissing out of the air stone. When you place the stone in the water, it should immediately start creating a plume of bubbles. Holding the stone deeper under the water should create slightly larger bubbles.
Step 4: Setup All Your Air Stone in the Bathtub
Now run all the tubes into the tub. You can just set them in loosely. But if you want to hold them in place you can just set a heavy shampoo bottle on the tubes.
Step 5: INFINITE BUBBLES!
Now all you have to do is turn on the pump and your tub will quickly fill with an endless stream of bubbles. It should only take a few minutes to completely fill the tub. You can now sit back and enjoy a nice relaxing bubble bath for as long as you want and you will never run out of bubbles.
Safety Note: The air pump should be waterproof if it is designed to be an aquarium pump. But to be extra safe, you should position the pump somewhere away from the tub where is won't get wet.
Step 6: Bonus: for Even Better Results, Add a Small Child
Everyone loves bubble baths. But nothing compares to the joy of a toddler splashing around in a mountain of bubbles. Try it out and have fun.
