Introduction: Bucket Buddy
The Bucket Buddy is a two person carrying system fabricated for individuals performing vocational tasks that involve lifting heavy containers or buckets. This distributes the weight of the bucket and its contents between the two users, effectively reducing overall load bearing and stress on an individual's body while promoting safe body mechanics.
Estimated Build Time: 2-3 hours
Tools:
- Router (with a round over bit)
- Drill (with a 1/4" drill bit)
- Jigsaw (with a wood cutting blade)
- Sanding Block
Materials with Measurements:
- Plywood (42" L x 7" H x 3/4" W)
- 1 J-hook or U-hook
- 1 Bolt (1/4")
- 2 Nut (1/4")
- 2 Lock Washers
Step 1: Before You Begin
Carefully read the instructions and ensure that you have all the required tools, materials, and correct measurements before you start building the device. Always wear protective gear when working with tools.
Step 2:
Outline the shape of the device on your plywood using the measurements provided in the Step 2 Diagram.
Step 3:
Cut the plywood, by following your outline, using a jigsaw.
Step 4:
Use a round over bit with a router, or laminate trimmer, to round the sharp corners on all edges of the plywood. Follow up with lightly sanding the surfaces.
Step 5:
To prepare for the middle hook piece; measure out and mark the center of the Bucket Buddy from both the vertical and horizontal directions.
Step 6:
Drill a hole at the marked point with the 1/4in drill bit. Then take the 1/4in bolt, with a washer attached, and feed it through the hole.
Step 7:
Finally, attach the J-hook to the bolt and finish the piece by installing the second washer and nut set to lock in the J-hook.
Step 8:
Your device is ready to use. If this interests you, give us a favorite and drop a comment below. Thanks for building with us!
DISCLAIMER: The Center for Discovery, Inc. (TCFD) works with Instructables to make the following information available for informational purposes only. TCFD, its agents, successors and / or assigns make no express or implied warranty of fitness or merchantability for any particular purpose for the items depicted. The reader should understand that the construction of this item is intended for use by an individual with cognitive or physical impairments (end user). This may pose a higher risk of injury to the end user. TCFD advises there is also a risk of injury to the individual constructing the device. The reader agrees to undertake the appropriate steps to lessen or eliminate risks of injury occasioned by the construction or use of the items depicted. Any and all losses, injuries or damages incurred by or resulting from the use of the information in this publication are the sole responsibility of the reader and end user, all of whom voluntarily, expressly and completely release, forever discharge, and agree to defend, indemnify and hold harmless TCFD, its agents, successors and / or assigns, from any and all claims, demands, or causes of action, which are in any way connected with the use of the information contained in this publication.
