Bucket Mouse Trap (kill or No Kill)
71,805
48
8
Introduction: Bucket Mouse Trap (kill or No Kill)
Catching mice is easy with a bucket mouse trap. Mice walk up the ramps, jump to the peanut butter which is applied to a round container and spins when the mice land on them. When you wake in the morning you'll either have drowned mice or, if you choose to not kill them, a bucket full of mice.
Happy Hunting!
Step 1: Parts and Tools
Parts
5 gallon bucket
2" PVC coupler
2 X 2" PVC end caps
Wire hanger
You'll need something to use as ramps. We found some cardboard and foam board lying around the house. You can use yard sticks, small pieces of wood, or anything the mice can use to get to the edge of the bucket.
Tools
Drill
Small drill bit (the size of the wire hanger)
Pliers
Step 2: Wire Hanger
The wire hanger should be wider than the bucket. Cut the long and straight part of the wire hanger using pliers.
Step 3: Prepping the Bucket
Drill two small holes near the top of the bucket to thread the hanger.
Step 4: Preparing the Roller
Assemble the roller by inserting the end caps into the coupler. Drill a small hole into the center of both couplers.
Step 5: Threading the Wire
Thread the wire hanger that you cut through the holes in the bucket and the holes in the PVC end caps. Using pliers turn up about an inch at either end of the wire to keep the wire from sliding out of the bucket.
Step 6: The Bait
Spread peanut butter evenly around the cylinder.
Step 7: Finished
All you have left to do is lean a couple of ramps against the edge of the bucket. You can use anything as a ramp from yard sticks to cardboard (as shown in picture).
Step 8: Kill or No Kill
Kill: Fill the bucket with 4" of water
No Kill: Plan on taking your bucket outside to free the mice that loved the peanut butter spread all over your new mouse trap.
Be the First to Share
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    8 Comments
    DaveT2
    DaveT2
    2 years ago
    It's a great design, but there are two problems with the no-kill option.
    First, if you release the mice anywhere near the location where you trapped them, they'll quickly be back.
    Second, if you release them at a sufficient distance to prevent their return (which is illegal in many states), they'll likely die anyway, because no matter where you put them there will already be mice present, who will viciously defend their territory, and the invaders or the defenders will die. Or the invaders will die of starvation, since they don't know their new territory. To my way of thinking, either of these option seems less humane than drowning.
    I'm going to try Mouse-X and RatX first, which are specifically deadly to rodents and which don't poison predators that eat the poisoned rodent.
    pdfsendohio
    pdfsendohio
    Reply 5 days ago
    Dude killing the mice is the objective, especially with chickens. They invite the predictor that will eat either , I relocate snakes to take care of the mice. 24-7
    Maniacy
    Maniacy
    7 years ago
    Dude come on, DROWNING mice? You should seriously consider changing that choice into a "Don't put water in the buckets because drowning mice is inhumane."
    zoressamarias
    zoressamarias
    Reply 2 years ago
    Would you mind if the mouse catcher brought them over to your yard. Then you can care for them.
    SheilaY1
    SheilaY1
    7 years ago
    Ive personally made one similar and these work great! A tin can with both ends can work in a pinch. For those of you concerned with drowning mice? Simple, dont add water. For those of us with a fear of disease, dangerous destruction of home, food and possessions, including thousands of dollars worth of possible damage to your home and car, add water. Rats are large and tricky and from my experience can reach from the edge of the bucket to the can without ever leaving the edge. In my experience, this works best with small field mice and the like.
    JorelH
    JorelH
    Reply 6 years ago
    Agreed,i like it,works if you people are afraid to kill a pest that deficates on your kitchen counter, add some booze to it that's alright, the thing will die happy, no more poop.
    I like the options available on this project, also the price point, and clever design. Thanks for sharing!
