Introduction: Budget Cold Steel Viking Hand Axe Improvement
While the Viking Hand Axe is a fairly handy tool, its novelty features and lack of mass don't lend themselves to mounting its head on such a long handle. I resolved to try a shorter handle and while I was at it added some personal touches on it.
Step 1: Test Fit to New Handle
I purchased a replacement throwing tomahawk handle for a Missouri River Company tomahawk. It's geometry was not meant to fit the Cold Steel head however, so some stock had to be removed.
Step 2: Sand Handle to Proper Dimension
Identify where to begin the sanding process on the handle to avoid removing too much material. I stopped and rechecked the fit periodically to reassess where to sand.
Step 3: Strip Clear Coat From Axe Head
Using Jasco paint and epoxy stripper, coat the head completely to avoid sections that won't take the blueing treatment. I also used a wire brush to scrub the nooks and crannies that are a little more tenacious.
Step 4: Apply Blue
I chose Berchwood Casey Super Blue to get the desired effect. Per the instructions on the bottle, apply the blue to the whole surface, allow to set for 30 seconds and rinse. I repeated the process 9 times to get the dark color I wanted.
Step 5: Apply Walnut Stain to the Handle
After reshaping the handle I sanded it with 400 grit sandpaper to smooth it out. After blowing it clean of dust apply your chosen stain. I used Berchwood Casey Walnut Stain. Apply the first coat uniformly over the surface and allow it to dry. I added a second coat and was satisfied with the color.
Step 6: Final Assembly
Once your head and handle are dry, simply slip the head into place and set tight to avoid wabble while in use.
DONE!
6 Comments
6 years ago
Very cool project! I wouldn't mind having a handy axe like that.
Reply 6 years ago
it's a handy little tool that doesn't weight my belt down but still has the "chops" to do the job.
6 years ago
I like the bluing, but It would have looked better with the edge still shiny. Now that it's blued, you could etch a nice Celtic knot design into the sides of the axe blade.! :)
Reply 6 years ago
I will be touching the edge up and eventually using my bandsaw strop to polish it. I'm unfortunately not skilled in the finer work and not confident I could add knot work to the blade. I'll just gaze at my tattoos in the meantime.
6 years ago
Did the "Taiwan" stamp come out when the head was stripped?
Reply 6 years ago
it didn't. you could easily hit it with a heavy grit sand paper or kiss it with a grinder and it's point of origin would then be unknown.
