Build a Custom Chalk Holder
Intro: Build a Custom Chalk Holder
Are you or is some one you know something of a pool shark? Well do I have the instructable for you! This is a great gift for the billiards buff in your life! Enjoy! If you have any questions or comments please ask and if you like it then vote! Thank you.
STEP 1: Shape the Brass
Using the brass rod of your desired thickness cut to 4-6"
Plan out the design you want on the shaft.
Insert the rod into your drill press chuck.
Turn the speed on the drill press to high
Using an assortment of files, shape the brass to the desired contour. Basically what you're doing is using your drill press as a lathe. So use safety!
Sand a flat area at one end and drill a hole through it to attach the key chain.
Using fine grain sand paper, sand and then polish the brass.
STEP 2: The Leather
I used an 8oz leather but I'd suggest around a 5oz. Cut a 1.25" x 6" strip of leather.
Wet leather.
Measure and notch as shown in the photos.
Wrap around chalk to shape and let dry.
Finish shaping and trimming leather.
Punch holes and affix grommets.
Wet leather.
STEP 3: Finishing and Final Thoughts
I used leather glue to secure the two ends together at the grommets. Use your choice of leather dye and final coating. Then attach key chain.
Final thoughts, I really dig the way this turned out, I made this as a gift for a family member that plays in a pool league. Please vote and share any that you build!
7 Comments
desertsniper 10 years ago
3366carlos 10 years ago
horseman woodshop 10 years ago
sokamiwohali 10 years ago
psycophonic 10 years ago
