Build a Smartphone Projector With a Shoebox
Intro: Build a Smartphone Projector With a Shoebox
Did you know you can turn an old shoebox and some office supplies into a Smartphone Projector? Yes you can! It is a fun, simple and easy physics experiment that you could do at home. Learn and observe how light
The project has been around the net for a long time, but here's a brief and detailed tutorial I made for everyone. (Most of my new videos will be made as brief and detailed as possible. Enjoy!)
Please do check my new YT channel:TechBuilder
If you like my past 4 episodes, feel to: Subscribe
I'm back guys! During my very long absence of not posting projects here in instructables, I was shooting and compiling lots and lots of video tutorials to preserve the continuity of my new channel. Every week, I'll be posting new and random projects. So most of the Instructable tutorials that I will be posting, will start to have a video tutorial attached to it. Please do subscribe, if ever you are interested. Thank you! ^_^
STEP 1: How Projectors Work
There are two major types of projectors in use as of this writing (things change pretty fast in the field). Projectors come with many features, strengths, or weaknesses, but most will run on either LCD or DLP technology. LCD is the older technology, but this does not mean that it is becoming obsolete by any means. LCD stands for Liquid Crystal Display. The way this places an image on a screen is fascinating and not nearly as complex as you might imagine. A bulb is set up to shine a fairly powerful light through a prism. The prism splits the light into its component colors and these are sent through small LCD screens. The screens themselves are sent signals to allow just so much of the light through at specific pixel locations. The light is then beamed through a lens onto a screen where the images can be seen by the human eye. DLP, or Digital Light Processing is a bit more complex. This time the light is shined through a spinning color wheel onto a chip that is mounted with hundreds of thousands of tiny mirrors. The mirrors are turned off or on by electronic impulses according to the need for the color at that moment. Even though only one color is shown at a time, one color follows another so quickly that the primary colors seem to blend into the appropriate color. The image appears to be constantly lit, when in fact small parts of it are constantly flickering. This technology was developed by Texas Instruments and is based on an older technology that was used for color television in the 1950s. Knowing the difference between these two types of projectors can be important, as LCD is considered better for static or high-contrast images. DLP, with its more vivid colors, is thought to be better for video. Some DLP projectors, have been known to manifest a rainbow effect. This can happen when white objects move on a dark background. Small shadows of red, blue, or green may be seen. Most modern DLP projectors have overcome this problem with multiple chips and higher rotation rates for the color wheel. So to what uses can we put these amazing machines?
This is not mine. This article was taken directly from: indepthinfo.com (source)
STEP 2: Thing You'll Need
Materials:
- Magnifying Lens
- Foam board
- Smartphone
- Gluesticks
- PVA Glue
- Shoebox
Tools:
- Hobby Knife (XACTO)
- Hot Gluegun
- Cutter Knife
- Hacksaw
- Ruler
STEP 3: Remove the Handle
Carefully use your hacksaw to cut off the handle of the magnifying glass.
STEP 4: Reinforcement
Reinforce the box by gluing the flaps and corners of the box. This prevents it from wiggling.
STEP 5: Let It Dry
Don't get too excited. Let it dry for a few minutes.
STEP 6: Lens Placement
Position your box in an upright position. Place your magnifying lens on top then center it. Use a pencil to trace the cut line.
STEP 7: Cutting the Perfect Round Hole
Here's a simple trick that I used all the time. If you are too OC, you can use an XACTO knife at the other end of a compass for cutting a perfect and round hole.
STEP 8: Pop!
Push it, pop it!
- This is satisfying! Feels as if you were popping a bubble wrap. :)
STEP 9: Position Your Lens
Position your lens before gluing the it in place.
STEP 10: Glue the Lens in Place
STEP 11: Cut Off the Protrusion
When you put the lid back on, the lid could block a portion of your lens (depending on the size of your lens or box). Use your precious cut out as a stencil then carefully slice off the excess cardboard that's blocking your lens.
STEP 12: Build the Phone Stand
Build a phone stand using a foam board. Make sure it's perpendicular from the base to avoid image distortion.
STEP 13: Tape Your Phone
Use a double sided padding tape to mount your phone on the stand.
STEP 14: Set Your Phone
Set your phone to the highest brightness:
Simple, more light results to a brighter projection.
Don't forget to lock the screen:
The lens inverts the light source (your phone's LCD) to the projected image. This means you'll have to position your phone's screen in a topsy-turvy position in order to prevent it from auto rotating. Go set the lock-screen setting and disable the auto rotate.
Flip The Image: (optional)
Download an app that flips the orientation of the image.
STEP 15: Adjust Your Projector
Like all projectors, this one needs to be calibrated too. Position your phone at the very end of the box then slowly move it closer to the lens, you will notice that the image will turn sharper/ softer. Move it back and forth until you get the sharpest projection.
STEP 16: Turn Off the Lights - Watch in the Dark
Turn off your lights, wait for it to get dark then Enjoy!
__________________________
Please do check my new YT channel: TechBuilder
STEP 17: So Stay Tuned! There's More to Come!
TechBuilder Season #1 Includes:
- Minty Microphone Preamp
- Ultraportable Spud Canon! (This one's a killer. Promise! It's made from a stubby waterjug!)
- PVC Camera Slider
- Supercharge A Cheap Mini China RC Car (30,000rpm motor mod, Bluetooth Phone Control, LiPo, 30A ESC)
- Studio LED Lighting Panel (shown in the last few second of my projector video tutorial)
- Make A Cotton Candy Machine (using kitchen supplies)
- All You Have to Know About Greenscreening
- Funny Tissue Paper Dispenser Hat
This is the reason why I've been gone for so long. :)
145 Comments
PedroHenriqueGuida 8 years ago
I have made one for me, it worked well, I also made a modification with a little mirror to get the image not flipped horizontally.
IDoNotSayBlaBlaBla 2 years ago
DhruvilS 7 years ago
monster mrinal 8 years ago
hey i dont know who are you but plzz tell me which mm glass did you used i tried it with 75mm of glass but it was not working plzz help me out thanxx for your prisious time
ASCAS 8 years ago
Next Project: "Car Horn Rigged Alarm Clock"
Any insights or suggestions on what you guys want to see on my next instructables/ YT video tutorial? :)
oggol 8 years ago
My alarm clock causes an earth quake.
kevin_28 8 years ago
ASCAS 8 years ago
Salamat tol! ^_^
ASCAS 8 years ago
Yung iba napanalunan ko sa contest dito sa instructables. Yung mga clone ko na Arduino nabili ko lang dito sa pinas, sa E-gizmo at sa Alexan. May website sila sakaling naghahanap ka, igoogle mo na lang. :)
kunalnc17 8 years ago
i want to see something which is practical for our dailly life
or atleast sometimes
and what is use full for a 11 year old child like me
ASCAS 8 years ago
That's nice! Half of my upcoming video tutorials will be about building practical projects, the other half is just building projects for fun (ones listed in step #17). The practical ones are about making projects related to renewable energy (solar charge controller circuit, complete combustion stove burner, wind turbine, etc...). They aren't for young ones though. Do you have any suggestions that you want to add to my list?
kintamera 3 years ago
saisanjay272 3 years ago
meredith.hodgkinson 3 years ago
ghazaleh.moghaddamjoo 4 years ago
adibaasad2323 4 years ago
ayush.ku.768 4 years ago
Its aperture
Or can u send me the link of that ???
ducreter 4 years ago
