Build Your First IOT With a Raspberry Pi, DHT11 Sensor, and Thingspeak.
Intro: Build Your First IOT With a Raspberry Pi, DHT11 Sensor, and Thingspeak.
IOT or Internet of Things is a hot topic! According to the experts everything will be connected to the internet and all our devices and their data will soon be just an IP address away from us. So where do you start if you want to explore the world of IOT? How about a simple Temperature, Humidity, and Light sensor for your basement.
Summer is here and being in the Northeast that means HUMIDITY with a capital HUMID. Many of us have some sort of de-humidification system in our basements. My workshop is in my basement and I have a small dehumidifier that keeps it nice a dry during these months. Despite the basement being humid it is also cooler than the above ground summer temps. I decided that I wanted to know how cool and how humid it can be and thus it became the inspiration for my first IOT project.
DHT11 sensors measure temperature and relative humidity and are cheap. Perfect for a first project. The DHT11 is not what I would call "scientifically" accurate but it is good enough to monitor my basement. While I was at it, I figured I might as well add a light sensor to know if I left the lights on. Another simple and cheap solution, all I need to use is a photoresistor.
Where to put the data became the next question. I could build a web server, but I wanted this to be simple so I decided to leverage a service called Thingspeak that has an API and will let me post and review the data from my IOT monitor.
STEP 1: What You Need to Complete This Project
Lets get started on building our project. We will build this on a breadboard, so no need to worry about soldering, or a designing pcb. Once we are happy with the design we can do that.
Hardware:
-Raspberry PI 2 & SD Card with Raspbian Operating System
-USB Power Supply
-USB Cable
-Breadboard & Jumper Wires
-2 x DHT 11 sensors
-2 x 10K Resistors
-2 x Photocells
-2 x 1uF Capacitors
STEP 2: Prep the Raspberry PI
If you have not done so, load Raspbian on your Raspberry PI. If you don't have a Raspberry PI, you can get one at Soldering Sunday that includes NOOBS pre-loaded on the MicroSD card or you can follow our guide to loading the Operating System for your Raspberry PI.
Once your Raspberry Pi is up and running we need to setup Python to talk to the GPIO pins. The GPIO pins are our interface to the DHT11 Temp/Humidity sensor and the photocell. For a deeper look at the Raspberry Pi GPIO Pin's go to our GPIO Tutorial.
Configuring Python
Not all the libraries we need to make this project are pre-loaded on the Raspberry Pi. You will need the Adafruit GPIO Python library and the Adafruit DHT 11 library.
We will use Adafruit's guide and library for setting up Python to communicate with the Raspberry Pi GPIO pins.
https://learn.adafruit.com/adafruits-raspberry-pi-lesson-4-gpio-setup/configuring-gpio
We also need Adafruit's Python library for the DHT11 sensor, which you can find here:
https://learn.adafruit.com/dht-humidity-sensing-on-raspberry-pi-with-gdocs-logging/overview
STEP 3: Raspberry PI - Understanding GPIO Pins
GPIO stands for General Purpose Input/Output and on the Raspberry Pi they are the physical interface between the software side of the Raspberry PI and the outside world. We will need to use the GPIO pins to connect to the DHT11 and the Photoresistor.
Different versions of the Raspberry Pi have a different amount of GPIO pins. In early versions of the Raspberry Pi there were 26 pins and the more recent versions have 40 pins. Even though more pins were added, pins 1 through 26 are the same on all versions. When you look at a reference for Raspberry Pi GPIO pins you will will find several notations for each pin. Most commonly you will find one reference for the physical name of the pin (1 to 40) and the other for the GPIO Name (GPIO1, etc). The physical name is just that, the physical ordered number of the pin. With Python we will be using the GPIO reference for our pin identification. The GPIO Name is designated from the chip set and more commonly used in advanced projects.
Referencing the wrong GPIO Pin number is very common and if you are not getting the results you expect when working with GPIO, double check the pin you are connected to and the pin you are referencing in your code.
If you would like a more in-depth review of the Raspberry Pi GPIO pins, we have a tutorial on them on our site.
STEP 4: Build the Circuit
We are keeping the circuit simple and building it on a breadboard using our components and jumper wires. Before connecting anything to your Raspberry PI, disconnect the power.
Warning - you can destroy your Raspberry Pi with a short circuit from a wrong connection. Just be careful and double check everything before powering back on.
To connect from the Raspberry PI to breadboard I like to use Dupont Cables, they are jumper wires that have a female side and a male side. The female side connects right to the male header pins of he Raspberry Pi and the male side plugs right into the Breadboard.
For this circuit we need to use the 3.3v out from the Raspberry Pi Pin 1 (do not use the 5v on Pin 2) and we need Ground (GND) of course. Connect these from the Pi to the Breadboard.
The DHT 11 has 4 Pins. Pin 1 is VCC, Pins 2 is Data, Pin 3 is NOT USED, Pin 4 is Ground.
- Connect DHT 11 Pin 1 to 3.3v
- Connect DHT 11 Pin 2 to Raspberry PI Pin 16/GPIO 23 and connect a 4.7 or 10k resistor from DHT 11 Pin 2 to DHT Pin 1
- Connect DHT 11 Pin 4 to Ground
The photo resistor has 2 pins
- Connect one pin to 3.3.v
- Connect the Other Pin to Raspberry Pi Pin 18/GPIO 24
- Connect a 1uF Capacitor to the same pin that the photo resistor is connected to on GPIO24. The Ground (White Stripe) side of the capacitor should go to Ground.
Check your work against the attached Fritzing Diagram and the photos.
STEP 5: Setup Thingspeak for Our IOT Data
Our Python script is going to read data from the DHT11 sensor and the photoresistor and then publish the values of that data to our channel on Thingspeak. First we need to set it up.
Go to Thingspeak.com and create a free acount or login to you existing account. Click on "My Channels" and then click on New Channel. Name your new channel and name the fields. The order of the fields is important later when we post data. They can be in any order, but when you post the data the data you need to remember position.
You can decide if you want the channel to be public or not as well as publish information about it's location. This is all up to you and will not affect our code. You will also need the Write API key for the channel as it will be required to post data to the channel.
STEP 6: Mini-intro to Python
Python has been around for many years and is has made a roaring comeback as the goto language for developers of all skill levels. It is an easy and clean language for the beginner and a powerful option for the advanced developer. It was a perfect choice for the Raspberry Pi. On the Raspberry Pi you will notice that there is a Python 2 and a Python 3 option. We will be working in Pyhton 3.
Why Python 3?
Good question. To answer you I will quote from the Python Wiki: "Python 2.x is legacy, Python 3.x is the present and future of the language"
Where can I learn more about Python?
Start at the source, python.org or try your hand at Python onlie at Code Academy. For a tutorials on Python on the Raspberry PI go here.
Launch IDLE on the Raspberry Pi
Most programming languages have a Integrated Development Environment, or IDE, and Python is no different. For Python it is called IDLE which also stands for Integrated DeveLopment Environment. IDLE is essentially a souped up text editor that understands you are coding in Python and will highlight your syntax and provide shortcuts to help you write your code. It will also help validate that your syntax is correct.
To Launch IDLE on the Raspberry Pi go to MENU -> Programming -> Python 3
To start writing our script go to FILE -> NEW and a new, untitled window will appear. This is where we will actually write our code. Save and name the file before we begin. Go to FILE ->Save and the file myfirstIOT.py
Take note of the directory you saved it in. It is probably /home/pi
Don't forget to add the ".py" at the end of your file, IDLE will not add it automatically.
STEP 7: Create the Python Script
Download the attached Python Script. You can copy paste to your IDLE session or download it to your Raspberry PI and save it in the /pi folder.
Before running it be sure to edit your API key from your ThingSpeak channel - edit this line:
#Setup our API and delay
myAPI = "***Insert Your API CODE HERE***"
STEP 8: Start Your IOT Engine!
We are ready to turn on our IOT engine - all we need to do is run our script.
Open LXTerminal. At the default command prompt you should be in the /pi directory already. You can type LS to see the file listings and the myfirstIOT.py should be there. We need SUDO (administrative) rights for script to access the GPIO Pins, so run the script as follows:
sudo python myfirstIOT.py
You should see the base url printed with your API key and the next line will be data from the DHT 11.
Each line printed locally will display:
Temp (c) - Temp (f) - Humidity - Light ( 0=off / 1=on)
Then go check you Channel on Thingspeak, you should have data.
SUCCESS! You Did it!
You are now part of the Internet of Things revolution.
In the age of Google and mass collaboration, it must be said that nothing we are doing here is original or has not been done before. We are just putting together components of software and hardware to solve the challenge we have. With that said, it means that if I can do it, you can do it too. What will you do next? Take this and expand on it.
46 Comments
jussipla 7 years ago
Here's the fixed python below. The downloadable python seems to have some serious copy-paste issues. :(
I also cleaned away the photo sensor bits as I don't have it, but you can use the original downloaded version. My script uses GPIO4, but you can change that easily. Also change the thinkspeak channel key.
Thanks for the original poster a great project.
---- code below ----
My First Internet of Things
Temperature/Humidity Light monitor using Raspberry Pi, DHT11
Data is displayed at thingspeak.com
2015/06/15
SolderingSunday.com
Based on project by Mahesh Venkitachalam at electronut.in
# Import all the libraries we need to run
import sys
import os
from time import sleep
import Adafruit_DHT
import urllib2
# Setup the pin we connect to
DHTpin = 4
myAPI = "insert_here_your_thingspeak_channel_key"
myDelay = 15 #how many seconds between posting data
def getSensorData():
RHW, TW = Adafruit_DHT.read_retry(Adafruit_DHT.DHT11, DHTpin)
#Convert from Celius to Farenheit
TWF = 9/5*TW+32
# return dict
return (str(RHW), str(TW),str(TWF))
# main() function
def main():
print 'starting...'
baseURL = 'https://api.thingspeak.com/update?api_key=%s' % myAPI
print baseURL
while True:
try:
RHW, TW, TWF = getSensorData()
f = urllib2.urlopen(baseURL +
"&field1=%s&field2=%s&field3=%s" % (TW, TWF, RHW))
print f.read()
print "tempC " + TW + ", tempF " + TWF+ ", humidity " + RHW
f.close()
sleep(int(myDelay))
except:
print 'exiting.'
break
# call main
if __name__ == "__main__":
main()
SiriTalasala 5 years ago
AlainB18 7 years ago
Here is the correct code!
Temperature/Humidity Light monitor using Raspberry Pi, DHT11, and photosensor
2015/06/15
SolderingSunday.com
import sys
import RPi.GPIO as GPIO
import os
import Adafruit_DHT
import urllib2
DEBUG = 1
# Setup the pins we are connect to
RCpin = 24
DHTpin = 23
GPIO.setmode(GPIO.BCM)
GPIO.setup(RCpin, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
TWF = 9/5*TW+32
# return dict
def RCtime(RCpin):
LT = 0
if (GPIO.input(RCpin) == True):
LT += 1
return (str(LT))
# main() function
def main():
print 'starting...'
print baseURL
while True:
try:
LT = RCtime(RCpin)
"&field1=%s&field2=%s&field3=%s" % (TW, TWF, RHW)+
"&field4=%s" % (LT))
print f.read()
print TW + " " + TWF+ " " + RHW + " " + LT
f.close()
sleep(int(myDelay))
except:
print 'exiting.'
break
# call main
if __name__ == '__main__':
main()
SagarB77 6 years ago
Hlw.......i ran this corrected code before six month, it worked.But now i
m trying to run this code and it doesn't run.Its says """""""starting
https://api.thingspeak.com/update?api_key=%sYHG5O...
gets stack.Nothing comes after it.I tally the code with original code
and removed maximum error.But this error is still left.Can you please
help me with complete code????Please :) :) :)
Samarjeet Chavan 7 years ago
Statements in this code are perfect. But if you copy paste the code here, You will definitely have indentation problem. Thus, i recommend to compare this code with the MyfirstIOT.py's code and complete the code.
Aaakashpowar231 7 years ago
Actually i m new to raspberry pi pls is anybody can help to add Adafruit library to my pi
King90 7 years ago
File "myfirstIOT.py", line 68
SyntaxError: invalid syntax
JeremyB86 7 years ago
Here is how to get the project to work:
Step 1
Replace my write API key Y5HGYOS51NFJ2I5O with your write api key in 3 lines (85,161 and 217).
Step 2
Save the file using the name dht11_thingspeak.py Iin the /home/pi folder
Step 3
You run the python script by entering this command in the command prompt. Replace YOURWRITEAPIKEY in the command with your write API key:
Here is the corrected python code:
#My First Internet of Things
#Temperature/Humidity Light monitor using Raspberry Pi, DHT11, and photosensor
#Data is displayed at thingspeak.com
#2015/06/15
#SolderingSunday.com
#Based on project by Mahesh Venkitachalam at electronut.in
import sys
import os
import Adafruit_DHT
import urllib2
DEBUG = 1
RCpin = 24
DHTpin = 23
myAPI = "Y5HGYOS51NFJ2I5O"
TWF = 9/5*TW+32
# return dict
def RCtime(RCpin):
LT = 0
LT += 1
return (str(LT))
# main() function
def main():
print 'starting...'
baseURL
#2015/06/15
import sys
import os
import Adafruit_DHT
import urllib2
DEBUG = 1
RCpin = 24
DHTpin = 23
TWF = 9/5*TW+32
# return dict
def RCtime(RCpin):
LT = 0
LT += 1
return (str(LT))
# main() function
def main():
print 'starting...'
print baseURL
while True:
try:
LT = RCtime(RCpin)
print f.read()
f.close()
sleep(int(myDelay))
except:
print 'exiting.'
break
# call main
#2015/06/15
import sys
import os
import Adafruit_DHT
import urllib2
DEBUG = 1
RCpin = 24
DHTpin = 23
TWF = 9/5*TW+32
# return dict
def RCtime(RCpin):
LT = 0
LT += 1
return (str(LT))
# main() function
def main():
print 'starting...'
baseURL
#2015/06/15
import sys
import os
import Adafruit_DHT
import urllib2
DEBUG = 1
RCpin = 24
DHTpin = 23
TWF = 9/5*TW+32
# return dict
def RCtime(RCpin):
LT = 0
LT += 1
return (str(LT))
# main() function
def main():
print 'starting...'
print baseURL
while True:
try:
LT = RCtime(RCpin)
print f.read()
f.close()
sleep(int(myDelay))
except:
print 'exiting.'
break
# call main
main()
print baseURL
while True:
try:
LT = RCtime(RCpin)
print f.read()
f.close()
sleep(int(myDelay))
except:
print 'exiting.'
break
# call main
main()
main()
print baseURL
while True:
try:
LT = RCtime(RCpin)
print f.read()
f.close()
sleep(int(myDelay))
except:
print 'exiting.'
break
# call main
main()
aroncey 7 years ago
Can someone make a correct version of this myfirstIOT.py file please
aroncey 7 years ago
wavesailor 7 years ago
Nice project - But could someone explain why the capacitor is used?
aroncey 7 years ago
Could someone post the actual correct python code for both sensors (as intended by the author). Thank you very much.
MichaelK139 7 years ago
3 copies of the same code, you commented out one.. you're a boof
mjrovai 8 years ago
Very good project. There are some confusion with your code (maybe someone damage it, good take a look). I did mine and worked fine. The tip of Thigspeak was great! Thanks a lot.
Bellow a video with my experiment, including a Twitter alarm.
AmanpreetS4 7 years ago
Does it works if someone has a DHT11 Sensor, that is not manufactured by Adafruit,
Since we don't have Adafruit products in India :(
Kindly Help
mjrovai 7 years ago
TheHobbyGuy 8 years ago
Kindly Help
