Build Your Own Mini Drill
Intro: Build Your Own Mini Drill
Hey! everyone My name is Steve .
Today i'm going to show you How to make a mini drill
You can use it for drilling pcb , wood & plastic etc
This drill can accept 0.8mm to 1.5mm drill bits
Let's Start
STEP 1: Stuff I Used
STEP 2: Building
- Clamp the pvc pipe on the tabe
- Use a hot air gun to soft the pvc pipe
- now insert the motor in the pvc
STEP 3: Connection
- Now connect 2 wire coming from motor to dc jack with screw driver
STEP 4: Building Cap
- I used 12mm MDF
- Now cut a hole using a 23mm hole saw
- Now drill 12mm hole in the center with step drill bit to fit the dc jack
STEP 5: Installing the Cap
- now glue the cap with dc jack using a super glue (as shown in the picture )
- now again use a hot air gun to soft the pvc pipe
- now insert the cap
STEP 6: Bit Adapter Install
- Now install the chunk on the shaft
- now install the drill bit
STEP 7: Running
- i used my bench power supply to power this up
- motor need 5v - 12v to run
You Just Made It
Now just Plug the power and enjoy
Thank you for visiting my Instructables Stay tuned for next Projects
5 Comments
computer freak3 7 years ago
Steve Willson Kujur 7 years ago
talonts 7 years ago
You could also trying drilling extra holes in the end plug to allow air in/out. The odds of plugging them with dust are pretty low considering they will be relatively far away from the drilling point and protected by your hand. If worried about the dust, a little cotton in each hole would filter decently.
EpicalAgent56 7 years ago
i've already provided the links
