Introduction: Build Your Own Real-Time PC Monitor With ESP32 & Arduino!
Learn how to set up real-time serial communication between your PC and ESP32. This project shows how data flows from your computer to your microcontroller using UART and how to display it effectively.
LilyGO T-Display S3 AMOLED (ESP32-S3 built-in)
USB-C Cable
Windows PC with Visual Studio (VB.NET)
Arduino IDE (latest version)
Optional: 3D-printed case
Step 1: Set Up Arduino IDE
Install the ESP32 Board Package:
Go to File → Preferences → Paste this URL in Additional Board Manager URLs:
https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
Tools → Board Manager → Search and install esp32 by Espressif Systems
Select board:
Tools → Board → ESP32S3 Dev Module or LilyGO T-Display S3 AMOLED
Step 2: Install Required Libraries
TFT_eSPI LINK-https://github.com/Bodmer/TFT_eSPI
Step 3: Upload ESP32 Code
Step 4: VB.NET PC Side Application
Copy the provided VB.NET EXE to any folder.
Run the app.
If COM port is not visible, check Device Manager.
The app will auto-detect the port and send data every second.
Step 5: Test & Debug
- Your ESP32 display should show performance data.
- If you send a custom message from the VB app, it shows on the 3rd page.
- Use the side button on LilyGO to switch pages (if implemented).
💡 Tips:
- You can easily modify the threshold values for alerts.
- Customize the layout or theme in the Arduino code.
- Add icons for a more attractive display.
- If you're only using it locally, no Wi-Fi is needed.
