Introduction: Build Your Own SD Card Chip | Arduino Compatible
Have you ever wanted to integrate permanent storage directly into your PCB designs without using bulky SD card slots? Meet the XTX XTSD04GLGEAG - a tiny SD card chip that works exactly like a standard SD card but can be soldered directly to your circuit board!
In this Instructable, I'll show you how to create a custom breakout board for this chip, interface it with Arduino using SPI, and build a user-friendly serial menu system to manage files. This project is perfect for embedded systems, data loggers, or any application where space is at a premium.
The best part? Once assembled, this chip works seamlessly with computers, 3D printers, and any device that reads standard SD cards - no drivers needed!
Hardware Components:
- XTX XTSD04GLGEAG SD card chip
- Arduino board (Uno, Nano, or compatible)
- Custom PCB (design files provided)
- 2.54mm SIL pin headers (2x5 pins)
- Solder paste (type 4 recommended)
- Soldering iron with fine tip
- Hotplate or reflow oven
- Breadboard and jumper wires
- SD card reader (for initial testing)
Software Tools:
- Arduino IDE (latest version)
- SdFat library by Bill Greiman
- Altium Designer (or your preferred PCB design tool)
- Serial terminal program (like PuTTY or Arduino Serial Monitor)
Manufacturing Services:
- JLCPCB or similar PCB fabrication service
- (Optional) 3D printer for enclosure
Step 1: Schematic and PCB Design
Start by designing the breakout board in your preferred PCB design software. I used Altium Designer for this project, but you can use KiCad, Eagle, or any other tool you're comfortable with.
Design Considerations:
- Create a schematic that duplicates the XTSD chip for top and bottom assembly
- Connect all chip pins to SIL connectors for easy breadboard compatibility
- Follow standard SD card layout for the edge connection if you want reader compatibility
- Set PCB thickness to 0.6mm - this is crucial for fitting into standard SD card readers
- Use 0.2mm trace width for signal lines
- Add clear pin labeling for easy wiring reference
Manufacturing Preparation:
- Generate Gerber files from your design
- Choose a solder mask color (I went with JLCPCB's signature blue)
- Select ENIG (Gold Nickel) surface finish for better solderability
- Verify all design rules before submission
Pro Tip: You can access my complete design files through the GitHub repository linked at the end of this guide.
Step 2: Circuit Assembly
Once your PCBs arrive, it's time for assembly. The XTSD chip has a QFN package, which requires careful soldering.
Soldering the XTSD Chip:
- Apply solder paste to all chip pads using a stencil or careful manual application
- Use tweezers to precisely place the chip on the pads
- Heat the board using a hotplate or reflow oven until the solder melts and reflows
- Allow the board to cool naturally - don't force cool it!
Microscopic Inspection:
After soldering, use a microscope or magnifying glass to check for:
- Bridging between pins
- Proper solder fillets
- Chip alignment
Adding Connectors:
- Insert SIL pin headers into a breadboard
- Place the PCB on top, aligning the holes with the pins
- Solder each pin using a fine-tip soldering iron
- Use copper braid to clean up any excess solder
Safety Note: Work in a well-ventilated area and use ESD protection when handling the chip.
Step 3: Wiring to Arduino
The XTSD chip uses standard SPI interface, making Arduino integration straightforward.
SPI Connection Diagram:
XTSD04GLGEAG → Arduino Pin
CS (Chip Select) → D10
MOSI (Master Out) → D11
MISO (Master In) → D12
SCK (Clock) → D13
VCC (Power) → 3.3V
GND (Ground) → GND
Breadboard Setup:
- Place the breakout board on your breadboard
- Connect power lines first (3.3V and GND)
- Connect the four SPI signals (CS, MOSI, MISO, SCK)
- Double-check all connections before powering on
Important: The chip requires 3.3V power! Do not connect it to 5V as this will damage the chip.
Step 4: Final Test and Results
Upload the Code:
- Install the SdFat library via Arduino Library Manager
- Open the provided Arduino sketch
- Select your board and port
- Upload the code to your Arduino
Serial Interface Test:
- Open Serial Monitor at 9600 baud
- You should see the main menu with 8 options
- Test each function:
- List files (should show any existing files)
- Create a new text file
- Write data to the file
- Read back the data
- Delete files (with confirmation)
- View SD card information
Cross-Platform Testing:
- Remove the board from Arduino
- Insert it into a computer's SD card reader
- Verify the computer recognizes it as a standard SD card
- Check that files created via Arduino are accessible
- Try copying files from your computer to the chip
