Build Your Own Slosh Tube
Intro: Build Your Own Slosh Tube
A slosh tube is a large PVC pipe filled with water and capped on the ends. It's a low tech piece of exercise equipment, it is however an effective workout tool. Best of all, you can build one yourself for about $25.
STEP 1: You Will Need . . .
Although there are variants to the construction of a Slosh Tube, this is the way I made my own.
For the "Pillar of pain" you will need the following, most of which can be purchased at the local hardware store:
MATERIALS:
4" x 10' PVC solid sewer pipe
4" PVC end caps (x2 for each end of the pipe; there are variants to what type of end cap that can be used)
Black Tape
PVC cement (make sure if you are using PVC use PVC cement; for ABS use ABS cement)
Water
TOOLS:
Measuring Tape
Waterproof permanent Marker
Hacksaw
Sharp knife/blade
MATERIALS:
Black Tape
Water
TOOLS:
Measuring Tape
Hacksaw
Sharp knife/blade
STEP 2: Cut . ..
With your Hacksaw cut off about 4" from the side that has the 'raised lip' if your pipe has one.
STEP 3: Remove . ..
Use the sharp knife/blade to remove the burrs left on the end after cutting with the hacksaw. wipe clean.
STEP 4: Measure & Mark . ..
Measure from one end to the exact centre of the pipe. Mark the exact centre. Please, unlike myself, make your line is straight. ;-)
STEP 5: Tape . ..
Where the mark has been made stick some black tape to mark the centre of the pipe.
STEP 6: Seal, Fill, Seal . ..
- Make sure there are NO burrs and the end is clean before using cement.
*You can use PVC primer before using the cement; I didn't use it for this tube but I've had better results using the PVC Primer
- use PVC cement to glue one end cap on.
- wait about 5 mins. to allow for curing/drying of glue.
- Fill the tube about half full of water (depending in how heavy you want the tube.)
- use PVC cement to glue the other end cap on.
Enjoy your slosh tube!!
8 Comments
l8nite 14 years ago
theRIAA 14 years ago
greenteaent 14 years ago
PKM 14 years ago
randofo 14 years ago
Phil B 14 years ago
bumpus 14 years ago
