Build a Bike Boom Box
Intro: Build a Bike Boom Box
How it all started: I ride my bike in a community ride every week, and the folks there wanted some way to enjoy music on the ride. I tried a regular boom box, but it's just not made for bike mounting. Being an engineer, I decided to make my own bike-mounted sound system. This is what I came up with.
Take a look at http://www.cathodecorner.com/bikeboombox/ showing the system in detail.
The amplifier circuit board is of my own design. It uses a Texas Instruments Class D stereo amplifier chip to provide 15 watts per channel of clean sound with very low battery drain. I designed a circuit board with everything needed for a nice bike system, including a charging port for your MP3 player.
The amplifier board details are http://www.cathodecorner.com/bikeboombox/cdamp/
STEP 1: The Components
The bike boom box is made of three main parts: the rack, the tube and the amplifier board. A pair of 6.5" marine speakers and a battery pack round out the system.
The amplifier circuit board is available from my one-man company Cathode Corner for $100 assembled. you may also download all the design info from my website and build your own if you are good at surface-mount assembly.
The 6" sewer pipe is available from any big plumbing supply house (not Home Depot or Lowe's, unfortunately) but needs to be cut carefully, a task that I describe how to do.
The bike rear rack is available at any decent bike shop. You may already have one on your bike.
Parts required:
A fully assembled CDAMP amplifier board with angle brackets
A battery pack, Li-ion 18650x4 series cells with protection circuit (Batteryspace)
A 14.4V Li-ion charger (Batteryspace)
A 5.5mm/2.1mm DC power plug to fit the amplifier board (Digikey or Mouser)
A pair of Kenwood KFC-1652MRB marine speakers (eBay)
Two each .250 and .187 quick-disconnect crimp terminals to fit the speakers
Three feet of two-conductor speaker wire, 18 to 22 gauge
A rear bicycle rack, standard aluminum type (local bike shop)
Two feet of 3/4" Sch. 40 PVC electrical conduit
18" length of 6" Sch. 40 ABS sewer pipe (big plumbing supply house)
One foot of 3/4" to 1"x1/8" 6061-T6 aluminum bar stock (hardware store)
A dozen #8x3/4" sheet metal screws
Two 8-32x1/2" machine screws, flathead preferred
Two 6-32x3/8" machine screws, nuts and lockwashers or nylock nuts
Tools required:
Electric drill and/or drill press
Fractional drill bit set, up to 3/8"
Countersink, #8 screw head
Hacksaw
#1 and #2 Phillips screwdrivers
Sharpie marking pen
Small file, square or flat
(optional) Large miter box or the parts to make one and a crosscut saw
Parts required:
Tools required:
Hacksaw
Sharpie marking pen
STEP 2: Cut the Tube
It's not easy to cut a piece of 6" sewer pipe with nice square ends. I ended up building a custom miter box for the task. Mine is not ideal; a carpenter could do a much better job of it. Feel free to copy my design which is pictured here. The pipe is 6-5/8" in diameter.
The boom box body is a 16 inch long piece of pipe. You also need to cut two pieces one inch long to be used as reinforcements for the speaker mounting screws.
STEP 3: Cut the Arcs
Cut each of the one inch long rings in half, using the miter box as a holding fixture. Then cut each of these arcs in half to make eight same-sized pieces. You will need six of these to build the housing.
STEP 4: Glue the Arcs in the Tube
You will need three large clothespin-type clamps and a fresh bottle of ABS solvent cement for this step. A reference line on the outside of the pipe is helpful to align the arcs at the two ends with each other. I used the printed text on the pipe as a reference.
Place the pipe end-up on a piece of newspaper. Apply ABS cement to the inside of the pipe where one arc will be placed. Use the arc itself to see how long of a cement spot to make. Then apply cement to the outside of an arc. Press the arc into the cement spot on the inside of the pipe, align the edges flush with each other, and apply the clothespin clamp. Align everything again, making sure the clamp is not skewed in our out of the pipe, which will make the arc wander up or down. Use a paper towel or rag to wipe off the excess cement from the joint.
Repeat for the other two arcs on that end. The gap between any two arcs will be about 3/4" to 1" wide.
Let the assembly dry for an hour (longer if it's cold outside). Then remove the clamps, flip the pipe over and cement the other three arcs into the other end of the pipe.
Let the whole thing dry overnight before mounting the speakers.
STEP 5: Drill the Amplifier Holes
The amplifier board has a row of connectors and switches on one side. It also comes with a pair of angle brackets that allow it to be mounted with two 8-32 screws. you can download a PDF file with a drawing of the panel hole positions and sizes at http://www.cathodecorner.com/bikeboombox/cdamp/CDAMPC-art.pdf. Print it out, cut out the rectangle and tape it to the tube to use as a drill guide.
Center punch the hole centers onto the tube.
Drill all the holes out to 11/64" first, which is the size of the 8-32 mounting holes at the ends of the row of holes. Then enlarge them all except the two end holes to 1/4", then drill the bigger holes out to 23/64" or 3/8", then the three biggest holes to 13/32".
Countersink the two end holes to fit an 8-32 flathead screw.
File out the double hole with a small file to permit a USB plug to fit through it.
Check that the amplifier board fits in the holes.
STEP 6: Drill the Speaker Holes
The speaker holes may be drilled in the tube after the cement has thoroughly dried on the arcs. Each speaker has six screw holes spaced equally around the edge. We use all of them for a stable mounting job. The speakers come with long stainless steel screws that require pilot holes to be drilled in the tube. A 7/64" bit is about right.
Set the tube up on end and place a speaker in one end. Rotate the speaker so that two mounting holes are centered on each reinforcement arc. Center the speaker on the tube and mark the holes with a Sharpie.
Remove the speaker from the tube and start each hole with the drill. Place the speaker back on the tube to double-check the hole positions and correct if necessary. Remove the speaker again and drill the six holes about one inch deep.
Turn the tube over and repeat the above procedure for the other end, being careful to align the holes at one end with those at the other end so that the speakers aren't rotated relative to each other (that would look bad).
STEP 7: Cut and Drill the Conduit Pieces
Cut two 10" long pieces of 3/4" PVC conduit. File the burrs off the ends. Mark each piece for three holes in a row, one in the middle and one 1-1/2" from each end.
Drill three 11/64" holes in each piece at the marked locations using a vise and drill press if possible, but a handheld drill will work. Drill all the way through the pipe since the other side needs large holes to let the screws through into the pipe.
Turn the pieces over and enlarge the holes on this side to 3/8" diameter. I used a Unibit step drill to save time.
The last photo shows what the finished holes should look like.
STEP 8: Mount the Conduit Pieces on the Tube
This is a tricky step because several pieces are flopping around at once. The goal is to attach the two pieces of conduit to the big tube so that the rack will sit on them in the right place.
First, temporarily install a speaker in the end closest to the amplifier holes using two screws. This is the front speaker. The rack's upturned front end will have to clear the speaker, so it has to be there to get the fit right.
Place the tube on the workbench upside-down, that is, with the bottom of the speaker pointing up. The amplifier holes will be about 30 degrees above center. The speaker has a center line molded into the grill to make it easy to align with the center of the rack.
Place the two conduit pieces on top of the tube and hold them in place with the upside-down rack. See the picture to understand what this means. Position the two conduit pieces about 1/4" away from the end of the tube with the speaker grill. This end has the upturned end of the rack also. Check the centering of the rack with the speaker grill to be sure the rack is properly positioned on the tube. While holding everything just so, get out your Sharpie (you had it handy, right?) and mark the tube at each end of the conduit. The important end is the one near the speaker, unlike the photograph.
Now take off the rack and conduit, and hold up one conduit piece at the mark. Using a handheld drill with a 7/64" bit, drill a hole through the conduit hole closest to the speaker. Install a #8x1/2" screw in the hole you just drilled.
Align the conduit carefully with the direction of the tube. Drill a hole in each of the other two conduit holes and install screws in them.
Repeat the procedure for the other piece of conduit.
Hold the rack on the tube-conduit assembly and see how it fits.
STEP 9: Mount the Rack to the Conduit
The aluminum bar comes into play in this step. Hold it across the rack resting on the conduit pieces, and mark where to cut it off and where to drill two holes that will contact the conduit. See the photo for details.
Cut the bar with a hacksaw, then cut another piece of identical length. File down the saw burrs.
Center punch the hole marks, then drill a 11/64" hole in each position with the two bars stacked on each other to get the holes in the same place. Or drill one bar and transfer the marks to the second bar, then drill it.
Now that the bars are made, use them to hold the rack onto the conduit pieces. Hold the assembly together with one bar in place. Put the bar against the rack's center support rod as shown. Drill 7/64" holes through the bar holes into the conduit, then install screws into these holes. Repeat for the other bar, but it doesn't have to be in any particular position. See photos.
STEP 10: Take It Apart
The rack and speaker have to come out to install the amplifier board, battery and speakers with cables. This seems backwards, but it's the only way to get everything installed properly.
Remove the screws that hold in the two rack clamping bars. Pull off the rack.
Remove the screws holding in the speaker and take it out.
STEP 11: Install the Amplifier
The amplifier and battery pack are installed in this step. First, some cables have to be made. Unfortunately, the Kenwood speakers assume professional installation is available and so don't come with terminated cables like the cheap speakers you can find at Target. So you need to crimp some quick-disconnect terminals on to some wire. The positive terminal is the standard .250" size, but the negative is the oddball .187" size. Radio Shack and Ace Hardware sell the necessary terminals. Get the red ones that fit smaller wire.
I used some wire from a standard audio speaker kit - 22 gauge zip cord with a black stripe on one wire for polarity identification. I made the black stripe be the minus wire and gave it the .187" terminal.
Strip about 3/16" of wire from the other end of the cables and attach to the speaker screw terminals as shown. Then connect the battery wires - red to positive and black to negative. Finally, mount the amplifier board in the tube using two 8-32 x 1/2" flat head screws.
Put two lengths of double-sided sticky foam tape on the battery pack along both edges of one side, then stick it into place on the bottom of the tube.
STEP 12: Install the Speakers
It's finally time to put in the speakers for real. Pull one cable out one end of the tube and the other speaker cable out the other end. Plug the terminals onto the speaker tabs as shown.
Now is a good time to test the system by plugging in a music player, throwing the power switch and seeing if music comes out.
Mount each speaker in its end using the six screws supplied. It's hard work. You can use an electric screwdriver (that's what we call a variable-speed drill with a #2 Phillips driver bit) to make it easier, but be careful as the screw reaches the end of its travel.
STEP 13: Finishing Up
Install the rack on the bike using the hardware and instructions supplied with it. Then install the boom box onto the rack with the two clamp bars and the four screws. congratulations, you're done!
It's time to mount the music player to the bike's top tube or wherever you want it. There are commercially available devices to do this such as the iConsole, but it's expensive. I use a 2x4" sheet of industrial-strength Velcro, wrapped around the top tube and stuck to the back of my iPod Nano.
A one meter long 3mm to 3mm audio cable is usually just right for connecting the player to the boom box. Use the USB cable supplied with the music player to keep it charged via the USB charging jack.
53 Comments
GabeP16 6 years ago
This is so awesome. I'm thinking about using this as a base and adding a battery pack in the cavity to power an ebike.
Barry_L 8 years ago
Very cool project, excellently designed :)
BryanM1 9 years ago
In the final portion of Step 9, when you are mounting the steel bars to the conduit - do you just screw into the conduit, or are there connectors (nuts) on the inside of the conduit? I would think these screws could come loose, thus making the metal plates fall off and the entire thing not be secured to the rack?
cjackson11 12 years ago
SG1Oniell 13 years ago
tinstructable 13 years ago
chadeau 13 years ago
paleologos_the_greek 14 years ago
zeroemission 14 years ago
it would be cool if you posted a youtube video so we could hear it in action. i like the punchier sound of sealed designs like this than the boomy sound of ported designs. i bet your rig sounds crystal clear.
if anyone is looking for a forum dedicated to bicycle stereos, stop by the bikeology website's forum. the owner of the site has built some pretty ambitious & LOUD trailer systems, but we'd like ANYONE with any kind of bike system or even just interested in them to visit.
as many different systems as people have built, it would be nice to have a community that shares info & ideas as well as a common place for everyone to show their rides off & just hang out.
Dracanse 14 years ago
DIY Dave 14 years ago
ThinkBeforeYouSpeak 14 years ago
abadfart 14 years ago
munirallarakhia 14 years ago
Gamer6460 14 years ago
I designed and dropped in my own Power supply, with 5v for USB, and regulated power for the amp and EQ.
I figure, that with a little bit of work, I can have something nicer than anything I could get at the store.
I'll send a link to some pics when I get it completed
bikerbob2005 15 years ago
http://www.oobject.com/category/boombox-bikes
now I is getting ideas.
cantthinkof bettername 15 years ago
nixiebunny 15 years ago
