Introduction: Build a DIY Knex Digital Camera Tripod (actually a Quadpod)
Uses all k'nex except for the bolt used to connect the camera to the k'nex. See my youtube video on how to make it and use it.
Step 1: Build the Base
Connect 2 blue or black connectors with a white rod, and add 2 half-moon connectors with 2 blue rods. See picture for help. Connect the two half-moons with a white rod, then add a white rod to one of the tops of the blue connectors. Add two yellow or red rods to the end of the half-moon connectors. Connect those with a orange connector. See pictures.
Step 2: Build the Camera Connector
Basically, find a bolt that will screw into your camera with medium (not too much) tension. Add a gray connector, and add a white rod to that. See 1st pic. Then, connect the white rod like you did on the other in Step 1. Before screwing into camera, add 2 or 3 blue spacers, since you want the TIGHTEST fit, because, you don't want your $300 camera to fall on your desk while recording a YouTube video (my scenario). I used 3 spacers on my Sony DSC-S650. Then, screw the bolt in, and you have just made a DIY camera Quad-Pod. In this instructable, I used my previous camera, since it takes horrendously horrible pictures inside. It takes good pics outside, but I am using my S650 on it. Virtually any camera will work with this, provided it has a tri-pod mount hole on the bottom. Have Fun!
