Introduction: Build a Maze-Solving Robot With Arduino – the Easy Way!
Ever wanted to create a robot that can think and navigate on its own? This guide will show you how to build a maze-solving robot using an Arduino UNO, IR sensors, and a few basic electronic components. No advanced coding or robotics experience is needed—just a passion for DIY and problem-solving!
What’s a Maze-Solving Robot?
Imagine a tiny, self-thinking robot that can explore and find its way out of a maze, just like a mini AI-powered explorer. Using infrared sensors to detect walls and obstacles, this robot follows the "Hand on Wall Rule" (Left-Hand Rule or Right-Hand Rule) to navigate through the maze. If you've ever built a line-following robot, think of this as its smarter, more independent cousin! (I’ve actually covered a similar project on our site, where I added a detailed explanation.)
How It Works
Our maze-solving robot is powered by three IR sensors and a simple yet effective left-hand rule algorithm to navigate through any given path. While more sensors could improve decision-making, we’re keeping things simple and fun! The challenge of building and fine-tuning its logic is what makes this project exciting.
  1. Arduino UNO & Motor Shield
  2. 3 IR Sensors for obstacle detection
  3. 2-Wheel Chassis & a Castor Wheel
  4. 2 BO Motors with wheels
  5. 2S Li-ion Battery Pack (5.6V–8.4V)
  6. Wires, screws, and some patience
Step 1: Circuit & Assembly
Wiring Guide
  1. IR Sensors: Connect the left, front, and right sensors to A0, A1, and A2 on the Arduino.
  2. Motors: Connect the left motor to M1 and the right motor to M2 on the motor shield.
  3. Power Supply: Use a 2S Li-ion battery pack to power the motor shield and Arduino.
  4. Placement: Ensure the IR sensors are aligned properly to detect walls accurately.
By referring to the Maze solving robot Circuit Diagram, you will get a detailed view of the circuit.
Step 2: The Code Breakdown
Using the AFMotor library, our robot reads sensor data, makes decisions, and moves accordingly. The logic is simple:
  1. Right sensor detects a wall? Turn right.
  2. Left sensor detects a wall? Turn left.
  3. both Sensors detects wall? Turn left
  4. No wall? Move forward!
// Maze Solving Robot Code
// This code is designed to control a maze-solving robot using the Adafruit Motor Shield and three infrared (IR) sensors to detect the robot's surroundings.
// The robot uses the IR sensors to sense the walls of the maze and determine the appropriate actions, such as moving forward, turning left or right, or performing a U-turn.
// Key Features:
// 1. IR Sensor Integration: Detects obstacles in front, left, and right of the robot.
// 2. Motor Control: Uses the Adafruit Motor Shield to control two DC motors for movement.
// 3. Decision-Making Logic: Implements a switch-case structure based on sensor states for navigation.
// 4. Customizable Parameters: Speed and delay values can be adjusted for smooth operation.
// 5. Debugging Capability: Serial output for monitoring the robot's behavior in real-time.
// The code is modular, with separate functions for forward movement, turning, stopping, and U-turns, ensuring clarity and ease of modification.
#include <AFMotor.h> // Include the Adafruit Motor Shield library for motor control
// Motor Definitions
AF_DCMotor motorA(1); // Motor A connected to terminal M1 on the motor shield
AF_DCMotor motorB(2); // Motor B connected to terminal M2 on the motor shield
// Sensor Pin Definitions
const int leftSensor = A0; // Left IR sensor pin
const int frontSensor = A1; // Front IR sensor pin
const int rightSensor = A2; // Right IR sensor pin
// Movement Parameters
const int forwardSpeed = 120; // Speed for forward movement
const int TurningSpeed = 115; // Speed for turning movements
const int turnDelay = 25; // Delay for completing a turn
const int uTurnDelay = 50; // Delay for completing a U-turn
void setup() {
// Configure sensor pins as input
pinMode(leftSensor, INPUT);
pinMode(frontSensor, INPUT);
pinMode(rightSensor, INPUT);
// Initialize serial communication for debugging
Serial.begin(9600);
void loop() {
// Read sensor values (0 or 1)
int leftValue = digitalRead(leftSensor);
int frontValue = digitalRead(frontSensor);
int rightValue = digitalRead(rightSensor);
// Combine sensor states into a single value for switch-case logic
int sensorState = (leftValue << 2) | (frontValue << 1) | rightValue;
// Decision-making based on sensor states
switch (sensorState) {
case 0b000: // No sensors detect a wall
uTurn(); // Perform a U-turn
Serial.println("Stop");
break;
case 0b010: // Only the front sensor detects a wall
moveForward(); // Move forward
Serial.println("Move Forward");
break;
case 0b111: // All sensors detect walls
turnLeft(); // Turn left
Serial.println("Turn Left");
break;
case 0b100: // Only the left sensor detects a wall
break;
case 0b110: // Front and left sensors detect walls
break;
case 0b001: // Only the right sensor detects a wall
turnRight(); // Turn right
Serial.println("Turn Right");
break;
case 0b011: // Front and right sensors detect walls
break;
case 0b101: // Left and right sensors detect walls
stopMotors(); // Stop the motors
break;
default: // Unknown sensor state
stopMotors(); // Stop the motors as a safety measure
Serial.println("Unknown State");
break;
// Function to move forward
void moveForward() {
motorA.setSpeed(forwardSpeed); // Set speed for motor A
motorB.setSpeed(forwardSpeed); // Set speed for motor B
motorA.run(FORWARD); // Move motor A forward
motorB.run(FORWARD); // Move motor B forward
// Function to turn left
void turnLeft() {
motorA.setSpeed(TurningSpeed - 20); // Reduce speed of motor A for smoother turn
motorB.setSpeed(TurningSpeed); // Set speed for motor B
motorA.run(BACKWARD); // Move motor A backward
delay(turnDelay); // Delay to complete the turn
// Function to turn right
void turnRight() {
motorA.setSpeed(TurningSpeed); // Set speed for motor A
motorB.setSpeed(TurningSpeed - 20); // Reduce speed of motor B for smoother turn
motorB.run(BACKWARD); // Move motor B backward
// Function to stop the motors
void stopMotors() {
motorA.run(RELEASE); // Release motor A
motorB.run(RELEASE); // Release motor B
// Function to perform a U-turn
void uTurn() {
delay(uTurnDelay); // Delay to complete the U-turn
Step 3: Testing and Troubleshooting
  1. If the robot moves erratically, check the sensor alignment.
  2. If the motors don’t run, ensure the battery pack is fully charged.
  3. Adjust sensor placement for better detection if needed.
Step 4: Conclusion
Congratulations! 🎉 You’ve built a simple maze-solving robot. This project introduces you to robotics, sensor-based navigation, and Arduino programming. To enhance it, try implementing path optimization or adding more sensors for better accuracy.
Looking for more projects? Explore our collection:Arduino IoT Projects | Arduino Robotics Projects | Arduino AI Projects | Arduino Home Automation Projects | Raspberry Pi Projects | ESP32 Projects.
Happy building! 🚀
