Introduction: Build a "Tuned" Pipe for a 2-stroke
Two stroke engines fascinate me. They are so simple and fun that I've always enjoyed tinkering with them. There are many ways to boost the power, one of which is by installing a "tuned" pipe. The way a two stroke motor works causes them to be fairly noisy and a bit inefficient. A tuned pipe has a set of cones- Divergent (meaning the cone gets bigger) and Convergent (meaning the cone gets smaller) that are built to cause "echoes" or pressure waves to reflect back, which if done properly can increase the power of the engine. Check out this link, it will make a little more sense.
Animation of Two Stroke expansion chamber:
http://upload.wikimedia.org/wikipedia/commons/5/52/Arbeitsweise_Zweitakt.gif
As the pressure wave reflects back, it has a similar effect to turbocharging or supercharging a 4 stroke- it rams fuel and air that leaked into the pipe back into the cylinder under higher pressure, causing the motor to have more power (more fuel & air = bigger bang). That's a very loose explanation, but there you go.
I've always wanted to build an expansion chamber... This is where P.O.J. (pronounced Podge) comes in. This Piece Of Junk was (and is) my first motorcycle... found it in a grain bin around '95, back when I wasn't allowed to have bikes. Somehow, this one snuck home. I dug it out of storage a few years ago and began this process, so follow along as I make mistakes and learn a thing or two about building your own expansion chamber!
Please note, this is NOT the only way to do this. I think there is an easier way- done by cutting out two sheets in the correct shape, welding the edges, and the pumping ultra high pressure water in to "expand" the pipe, but I didn't have the tools at the time to do it like that. This is just how I did it...
Step 1: Equipment, Skills, and Supplies.
This is NOT an easy quick project. It requires a lot of big, expensive tools. I'm lucky enough to have access to a shop that has everything I needed. There are alternate ways to make pipes, which I will discuss at the end of this instructable.
Skills you should have:
-Ability to Weld
-Ability to mark & cut metal ACCURATELY
-Understanding of and ability to use Shears, Brakes, and other metalworking tools
-Safe work ethic
-Understanding of 2 stroke engines
-Ability to use expansion chamber design software (OR, be really good at math or want to build 50 different pipes (trial and error))
-lots and lots of TIME
Supplies:
-Cold Rolled sheet metal- I used 18 gauge
-LOTS of welding rod- I used a 110v wire feed welder
-Rubber stoppers for isolation mounts
-Misc. nuts and bolts for mounting
-Duct Tape, shop towels, and band-aids. You never know!
Tools:
-Safety equipment- safety glasses, ear plugs, gloves, etc.
-Measuring & Marking tools- marker, scratch awl, steel rule, dividers, etc
-Squaring Shears
-Electric shears or aviation snips
-Hammer (ball pein works great!)
-Stake table with appropriate stakes
-Box and Pan Brake (could just use stake table but...)
-Welder (something capable of welding thin metal!) and related supplies- wire brush, clamps, gloves, helmet, safety gear, etc.
-Hack saw or metal cutting Band Saw
-Drill or Drill Press & drill bits
-Grinder and/or file
Other Usefull Things:
-2 Stroke expansion Chamber Software- I used 2 Stroke Wizard by Build and Click. Cost $20.00, came with a 4T header design program and a cone printing program that breaks large cones up to fit on 8.5x11 pages you can cut out and tape together. Great program. I tried a few free ones, but the first attempt at making a pipe from those didnt work so well...
-The Book Two Stroke Performance Tuning by A. Grahm Bell (apparently, not THAT A.G. Bell...)
-Someone who knows what they are doing, so you can ask questions! In my case, that was advrider.com
Step 2: A Little Groundwork Before You Build.
I'm not going to go into great detail, but you can't just build a pipe and throw it on there expecting it to work well. You have to know a lot of things about your engine- port size and location, port timing, desired application, etc. You will have to figure out all of this information.
Here is a VERY basic rundown of what you need to do:
Before you can start at all, you have to know your port timing. Port timing is measured in degrees. You need a degree wheel, which you can print from here: http://www.1130cc.com/gallery/files/9/1/Degree360CCW.jpg
Remove the head from you engine. Remove the engine side cover over the flywheel.
Set the engine at Top Dead Center (TDC)- meaning the piston is all the way to the top of the cylinder as far as it will go. Attach the Degree Wheel to the flywheel, and align it with something on the engine or use a laser like I did. it doesn't matter where the wheel is oriented, as long as whatever it is oriented with is pointing at ZERO. See Picture 1.
Rotate engine slowly in the direction it runs until you see the top of one of the ports. Make a note of which port is opening and the degree at which it opens. Continue rotating, taking note of when the ports open and close. You will have to do some math to figure out the Duration- the amount of degrees each port is open- and then you are *almost* ready to plug numbers in to your software.
I did my port timing on Sketchup, which allowed me to draw lines at the degrees I measured, then use the protractor tool to measure the duration. The results are shown in Picture 3, with RED being the Intake duration, YELLOW the Exhaust duration, and BLUE the transfer port duration.
***Quick side note about 2 strokes- you will notice the yellow and blue are open at the same time. Exhaust starts escaping the cylinder, then fresh fuel and air is being pushed in at the same time which also helps push the exhaust out. The problem is that some of that fresh fuel and air also escapes out with the exhaust- which is the whole point of a Tuned pipe- the pressure wave is timed so that it will push most of that fresh fuel and air BACK into the cylinder through the exhaust port while the transfer port is closed but the exhaust port is still opened. Whew. Clear as mud!?
One more thing we need to measure before we can begin- Port locations and sizes. This is a little harder. There are lots of ways to do this, but I'm just going to share with you how I did it on my bike. It's, well, sorta unique...
Remove the cylinder as shown in Picture 4. you can see a few of the ports we need to measure. We need to know the height from the top of the cylinder, their location to each other, and their size.
Line the cylinder with aluminum foil as shown in Picture 5. Try to keep the foil as un-wrinkled as possible. Take a balloon or a laytex glove, stick it over an air hose, and set it in the cylinder. Inflate the balloon, causing it to push on the foil and indent the outline of the ports. Let the air out and take the balloon out. As you can see (barely) in Pictures 6 & 7, the ports have been imprinted on the foil. Unroll the foil, and measure the size & location of the ports. You can see my results in Pictures 8 & 9.
***Another quick note on 2 strokes- you can change the dynamics and power of a 2 stroke engine a LOT just with simple porting. I didn't mess around with the porting (yet), but a good port job combined with a tuned pipe work far better than just a tuned pipe by itself. Again, it depends on what you want the engine designed for- you can't have a high rpm road race engine that will also perform well as a lugging slow revving engine.
Whew. Got all the info we need, and we're finally ready to start the design!
Step 3: Designing the Pipe.
Once you have all of your information gathered, you are now ready to design the pipe. There are two ways to do this- by hand using the equations and information in A. Grahm Bell's book, or by using a computer program. The first time I attempted to build a pipe I used a free online program. The pipe came out WAY too small. It worked, but only at extremely high rpms and it restricted the flow too much. For this attempt, I used a program called Two Stroke Wizard by Build and Click.
It was pretty simple to use the Build and Click software- fill in the blanks with all of the information you gathered, then click go and wait a minute or two. It spits out a nice sheet full of information including cone lengths and diameters at each end. Using that info, you can then make the cone printouts using the cone software that came with the program. Pretty slick! See the attached screen captures.
Step 4: Layout & Cutting
Now that you know the dimensions of the pipe you are going to build, we need to make some patterns. The software I used came with a sweet little add-on that allows you to print cone layouts by entering the length of the cone and the diameters at each end. It would then generate a flat layout that could be printed on multiple pages, cut out, and taped together. See Picture 1.
Once you have all of the cones and cylinder patterns, its simply a matter of tracing them on to your metal. I don't like making lots of cuts, so i tried to consolidate as much as possible by lining up long cuts with each other. You can see my finalized layout in Picture 2 & 3.
Once it's layed out on the metal, it's time to cut! This is where the Squaring Shears come in handy- its great for the long straight cuts (see Picture 4). I used a set of electric shears to cut out the curves, but aviation snips would probably do the job just as well (see Picture 5).
Once all of the parts are cut out, you are ready to start forming! As you can see in Pictures 6 & 7, I don't have the "header" or "stinger"- I used the stock head pipe cut to the length given in the design since it was the right diameter, and the "stinger" or last part of the pipe was so small in diameter I found a piece of pipe that was right and just cut it to length.
Ready to bend?!
Step 5: Forming the Cones- Slip Roller
There are two ways to form the metal for cones or cylinders. The best way for the cylinder is to use a Slip Roller like the one in Picture 1. It gradually rolls the metal tighter and tighter until you have a nice cylinder, then the top roller lifts and you slip the metal off the end of the roller (Pictures 2-7).
Finished cylinder, ready to weld! (See Picture 8)
This works really good for straight cylinders, but its a little harder to do with a cone that will have different diameters on each end. I've been told a trick to this is to pinch the short end of the cone with pliers to hold it back allowing the longer side to get sucked through faster (see Picture 9). This didn't really work for me because my rollers were to big for the cones I was making anyways. I think with some practice, though, it would work really good.
The other option is to "micro-brake"- see the next step!
Step 6: Forming the Cones- Box and Pan Brake
If you don't have a slip roller, don't be too worried because there IS another way! A sheet metal guy taught me this trick and called it "Micro-braking". It worked great. The theory is simple- You can take a flat piece of metal, put hundreds of small bends in it, and "curve" it around to make cylinders or cones.
Here's how:
Mark the cone by measuring each curve and then dividing the length by a set amount. For example, I decided on one of my cones I wanted to bend it every 7mm. I set my dividers to 7mm and marked that edge every 7mm. The OTHER end is a little more tricky. You need the same number of marks on the short end, so the marks are going to be a lot closer together. In my case, at 7mm I had 45 marks on the big end (see Picture 1). That means I needed 45 marks on the other side, which worked out to be a mark every 4.8mm. Its pretty simple math because you have all of the diameters for each side of the cone from the printout, you just have to find the circumference which ends up being the length of the arc you are working with.
***Quick note- on cones that have a big size difference, you may have to cut your number of marks in half or 3rds on the short side- meaning you will use a mark on the short side twice or three times before moving to the next mark.
Okay... So that may be kind of confusing. Lets put it this way- your markings will end up giving you a pie shaped section on the cone- always going down the center line of the cone.
Now we bend. Slide the metal under the fingers of the brake all the way until you can line up your first set of marks. Picture 2 shows a couple of bends done. ONLY BEND IT A TEENSY BIT!!! You can see in Picture 3 and 4 that I'm bending it too far. Not a real big deal, its pretty easy to straighten out.
Once you have the cone roughly bent (see Pictures 5 & 6) take some time with a hammer and the Stake Table to pound the cones into shape. The split needs to be as near perfect as possible to be welded. If I had taken more time on this one thing, my welding would have gone a LOT smoother! Get it as close as you can! See Picture 7 & 8. Picture 8 shows how close they should be for welding.
Finally. Time to melt some steel!
Step 7: Welding
Something else I've always wanted to be able to do is weld thin metal. This project was my excuse to give it a try. I do not claim to be any sort of an expert in the field of welding, so please take my tips and suggestions with a grain of salt... because they could be totally wrong. This is just what worked for me.
How to weld thin metal
I feel the most important thing for making these welds work is to have the two pieces aligned as perfectly as possible. Doing butt joints like this means there is a lot of heat right on the edge of the metal, making it very easy to melt or blow holes through it. Not fun, or pretty. I spent some time with some scraps getting my welder dialed in correctly (see Picture 1)- take your time, practice, and figure out what works for you!
***Note on welders- I used a 110v wire feed welder with a thick flux core wire. Not the best setup for this situation. Ideally, a wire feed welder with argon gas shielding should work better for thinner stuff, or if you have access and the skill to use it, a properly set up TIG welder would be the best option. My first attempt was done with an Oxy-Acetlyne torch, mainly because I wanted to practice using it. It can be done, but some machines make life a lot easier!
Once you've got your welder figured out, the first step is to tack the piece together. Clamp the ends tightly as shown in Picture 2, then tack weld (just a small spot to hold it together) it about every inch as shown in Picture 3. Now for the hard part.
I tried a couple of different ways to weld this thin metal together, and the best way I've found so far is to "zappy-zap"... Kind of a variation on "skip welding". Skip Welding (see Picture 4) is when you weld a short strip, skip to a different section and weld another short strip, and keep repeating until the whole piece is welded. It worked okay, but I found that it would build up too much heat and melt holes in my project.
My solution was to do shorter and shorter skip welds, until my skip welds were about 1/4" long and took about 1 second to do. Then I started just zapping it for a second, pausing for a second to let it cool slightly, zapping it for a second again (just long enough to get a nice puddle to form to ensure penetration), then letting it cool, and just repeating the whole way down the joint. This ended up working really well for me.
Tips on welding thing metal
1. If at all possible, weld DOWNHILL. You travel faster and build up less heat, making it less likely to blow holes in your project.
2. On the "zappy-zap" welding- if you are still blowing holes in the metal, you can also weld a spot, jump ahead about 1/4" and weld backwards into the already welded spot. This way, the hottest part of the weld is over top of THICKER metal (because you ended on top of your previous weld) making it less likely you blow holes in it. Weld backwards, jump ahead 1/4", weld backwards, jump ahead, repeat...
3. If you do blow holes in your metal, using a filler rod for acetlyne or TIG welding along with your MIG welder can put enough metal in the hole quickly without getting it too hot and making the hole WORSE. Just hold the rod in your left hand, keeping it over the hole, and weld over top of it with the MIG welder.
Welding your expansion chamber
Individual parts: Pick one of the cones or cylinders and start by welding up the joint as explained above. I started with the belly of the pipe (the center cylinder). Tack weld it together, then weld it up. You can do one piece at a time and then weld the pieces together, or you can weld up all of the pieces and then weld the pieces together.
Joining parts: Again, I can't stress how important it is that the joints line up as perfectly as possible. If you took your time during the layout step, they should be pretty accurate, but you will have to do some tweaking to make sure the ends you are joining are both perfect circles and that they line up with each other. The stake table and grinder can be your friend here- just be sure if you grind anything it IS absolutely necessary. Once you are sure they are lined up, tack the 2 pieces together as shown in Picture 7, then clean up the burnt flux if you are using a flux core welder, and start welding! See Picture 8.
***Note on joining pieces- If things don't line up great, tack it together where it DOES line up, then use your hammer and stake table to "adjust" the fit. You can get things very close this way if you are patient...
Keep on adding pieces until you are done! See Pictures 9-13.
So you have a pipe... How the heck is this thing going to fit on the bike!?
Step 8: Making the Pipe FIT.
Whatever machine you are building this for, its very unlikely that the port comes out of the engine in a way that will allow you a straight shot out to put your pipe on... which means we have to do a bunch more cutting and welding. We have to "curve" the pipe around both to avoid obstacles AND to make it shorter- 'cause you really don't want 3 feet of pipe sticking out behind your bike! There are two ways to do this- the easy way, and the hard way.
The HARD way (Pictures 2-5)
This is the way that was shown in A. Grahm Bell's book... And it's HARD. Requires a lot of thinking, planning, and way more welding. Goes like this:
1. Decide where you want the "bend" in the pipe.
2. Cut the pipe straight through.
3. On one side, starting at the widest point of the circle (the diameter) in the direction you want the pipe to bend, cut off a sliver at the angle you want the pipe to go. See Picture 2.
4. Weld the sliver back on to the same piece of pipe, just on the opposite side. See Picture 3.
5. Weld the other half of the pipe to the first half. See Picture 4 & 5.
6. Repeat for every bend...
As you can see, its very hard to get everything to line up nicely. I did the entire first cone this way, and was not pleased with the results. I ended up building a new first cone, and used the easy way on it. I feel it turned out MUCH nicer- and while it is more angular it was so much simpler to do.
The EASY way (Pictures 6-11)
Lots less cutting and welding.
1. Decide where pipe is to be bent and at what angle (Picture 7)
2. Divide angle in half (angle as measured from the centerline of the pipe, see Picture 8), cut pipe in direction you want it bent at half of the desired angle.
3. Rotate one of the cut halves of pipe 180 degrees, weld together (Pictures 10-12).
There are programs out there and if you enjoy math, you could sit down before you started building and figure out all of the angles for the cones and have done it in one fell swoop- basically eliminating this whole step. I don't enjoy math that much, and since this is a one-off project, it was easier to build the pipe, then cut and fit like this. Just keep cutting, welding, and test fitting (Pictures 13-15) to the bike as you go to make sure the pipe is going the direction you want it to go. My pipe came out better than I had hoped, but I do still think it could have been a lot better as far as fitting to the bike goes. Hey, its only my 2nd attempt, can't complain too much!
You can see in Pictures 16-29 How the pipe turned out. After I had experimented with both methods of bending the pipe, I went back and re-did the first cone of the pipe using the "easy" method, and it turned out much better.
Step 9: Mounting the Pipe.
Mounting the pipe can be a little tricky. Two strokes in general vibrate a lot, at a high frequency. The pipe is also containing pressure waves- expanding and contracting rapidly. This can cause parts to shake and metal fatigue, so you want to be sure the muffler you've spent so much time on is well mounted with strong brackets or "Hangers" to keep the pipe from shaking, fatiguing, and eventually breaking.
To help absorb some of these vibrations, I built some "isolation" mounts. These are not true isolation mounts in that the bolt goes all the way through the rubber and bolts solidly to the frame. Basically, its just a large rubber washer that will hopefully absorb some of the vibrations.
Building the Isolation Mounts
1. Drill a hole through a rubber stopper- the hole needs to be big enough for the bolt and the stopper needs to be big enough for your application. See Picture 1.
2. Cut the stopper in half- it doesnt need to be that tall! See Picture 2.
Building the Brackets
Once you have the isolation mounts built, you can start figuring out where to place your pipe hangers. According to the books, the best way to build the hangers is to use the same metal used for the pipe, but layer it so that it's twice as thick. This way, you also have two tabs to weld to the pipe- one on each side. See Pictures 3-4.
You will need to build your bracket to fit where it needs to go- take your time and lots of measurements! If you are using isolation mounts, be sure to take into consideration that it's a lot thicker so the bracket will need to be out further.
Attaching the Brackets
To attach the bracket to the pipe, tighten the pipe to the cylinder and make sure the pipe sits where you want it to be. Tighten the bracket to the frame. Tack the bracket on to the pipe, then remove the pipe and finish weld the bracket. See Pictures 6 & 7.If you are bending or forcing the pipe or bracket into position, things aren't going to line up well when you remove the pipe and it can put pressure on the pipe causing it to fatigue and fail.
Place brackets so that no large section of the pipe is left hanging freely- again, thats inviting metal fatigue both from the engine vibrating and hitting bumps while riding. In these pictures, the entire back half of my pipe is hanging free. I plan to add another long hanger behind the brake lever, as shown in Picture 7.
Step 10: Testing, Notes, and Finishing
Now that you think your pipe is "done, it's time to test. Ideally, you dyno'ed your bike before you did all of this work, or you at least know how much horsepower your engine makes stock. Check the fuel, oil, and whatever else is important, and fire it up! See Pictures 4 & 5.
VERY important Note!- Any time you make changes to the engine, there will be a domino effect- you change one thing, other things are now no longer tuned right. As was brought to my attention by maxpower49, I forgot to mention the domino of putting on a tuned pipe. Since a tuned pipe will generally flow more air through it, the jetting in the carb needs to be changed to match. If more air flows through the engine with the same amount of gas, it will cause a lean condition which can be VERY bad for your engine!
This can be fixed by installing a LARGER main jet. With a custom job like this, it's a process of trial and error that involves a lot of swapping of jets and lots of spark plugs. It's safer to guess rich (too big on the main jet) and then move smaller in little steps than it is to go larger in little steps.
Here's the quick version of how to jet your engine: Make an educated guess (and guess on the rich or large size). Install the jet and a NEW spark plug. Start the engine, let it get good and warm, and then shut it off. It works best if you can actually ride it for a bit to put the engine under load. Remove the spark plug and compare to the chart in Picture 6. You want the tip of the plug to be a nice chocolate brown. White or grey or totally clean means it's TOO LEAN, you need a BIGGER jet. Oily and black means its too rich, and you need a SMALLER jet. This could probably be an entire instructable in itself. Hmmm......
Testing
While its running, take a moment to inspect for leaks. One problem with welding it the way I did, if I wasn't paying close attention I would miss a few pinholes. They are very easy to locate when the bike is running- the pipe is under pressure so anywhere there is a hole, smoke will jet out. Mark the holes if any and be sure to weld them up.
If you have access to a dyno, run some tests! If not, there's always the "seat-of-your-pants" dyno. I measured performance by speed- my bike would top out at 50 mph in 4th gear with the stock pipe. With the first pipe I built, it would hit 50 mph in THIRD gear, but the power band was so narrow that as soon as I put it in 4th the bike could barely hold 50 mph.
Once you are satisfied with the location and performance of your expansion chamber, make it look good! Not just because you spent so much time building it, but because its metal, and it WILL rust. Thoroughly clean the outside of any oil, dust, or welding debris. A wire wheel on a grinder works great! Use a HIGH HEAT paint and apply a few good coats to prevent it from rusting.
I haven't quite made it to this step yet, I'm still building the rearsets, kickstand, and custom brake lever for my bike.
There you go! I hope you have enjoyed this instructable on hand forming an expansion chamber. Please check back for finished pics and the seat-of-my-pants report on how the pipe works. My goal is to be done by JUNE! The pipe is done, I just have to finish up a few other odds and ends.
Step 11: Resources
Software
2 Stroke Wizard by Build and Click- http://buildandclick.com/html/all_products.html
Books
Two Stroke Tuner's Handbook by Gordon Jennings
(pretty sure you can find BOTH of these for free as .pdf's if you look around...)
Links
My original build thread with LOTS more info: http://www.advrider.com/forums/showthread.php?t=655547
Welding Tips and Tricks! http://www.weldingtipsandtricks.com/
Wiki on 2 strokes: http://en.wikipedia.org/wiki/Expansion_chamber
Misc
Degree wheel- http://www.1130cc.com/gallery/files/9/1/Degree360CCW.jpg
The OTHER way to build an expansion chamber:
Finalist in the
Metal Challenge
45 Comments
8 years ago on Introduction
where can i purchase
Reply 11 months ago
go to kreidler.nl and find better software for this.
Question 3 years ago
Cool instructable, thanks!
I have a question. I have bought the software, they put in on an anniversary sale so it's only 18 USD now. Anyhow, I have a 50 cc Tomos moped with A35 engine. This engine was surely not designed for racing performance, however it couldn't hurt to make a fitting exhaust.
My top speed is 55 kmu @8850 RPM. I changed the port timings to 100 for the transfer ports and 150 for the exhaust, so I have a blowdown of 25 degrees. I still plan to widen the exhaust port. I want an exhaust pipe that is no longer than around 90 cm (excluding the silencer).
The original power is 1.42 kW, my first guess was to go for 5 kW of power. I have set the RPM @ max power to 7000 RPM. My exhaust pipe should now be 97 cm in total which is still acceptable.
What would you suggest I'd pick for a simple 2 stroke 50 cc engine if I want a little extra power in the lower rmp range? Seems to me that all the suitable RPM and peak power ranges result in 2 meter long pipes. Most of the stuff that's on the market is somewhere around 70 cm.
Answer 11 months ago
There are many cylinders for your engine. Airsal, Metrakit, and Athena are pretty good quality kits. Do include a small-end wrist pin bearing, and if you want to ride fast for a longer time, buy a Rito crankshaft. Combine this with Dell'Orto PHBG19.5 carburettor, esp. when you are converting to rotating disk inlet. Homoet exhaust and electronic ignition will make you achieve your goals. Don't forget about improving your brakes and insurance.
10 years ago on Introduction
C'mon, lets hear it going like snot(on the pipe for the layman)! Video with sound, please!
I know, eh?! My goal is to have it done by June. I will for sure have pics and vid of it running by then! I still need to rebuild the oil pump before I can run the engine, and I still have to finish the rearsets, rear brake assembly, and put the new front tire and tube on. Getting closer...
Reply 1 year ago
It's almost October, how is the Yamaha FS1 doing? Top speed, RPM, hp? Video??
4 years ago
hello, I bought a two-stroke wizard like you but I can not run and support does not match me. You can help me?
5 years ago
very cool topic thanks a lot for the info, I am working on the exhaust right now and purchased the software, wondering if it did what it supposed to?
6 years ago
Great article a really interesting read.l have 3 old Russian motorcycles all 350cc 2stroke singles,but with twin exhausts!.Do you know if the wizard click and build program would cover this scenario?I really fancy having a go at building my own pipes,not looking for silly rpm just a bit more torque. At this moment in time I am living in Bulgaria and do the bike rallies,a bit more grunt through the Balkan mountains would be handy
Reply 6 years ago
Sorry, we've upgraded our computer and haven't tried reinstalling the software so I can't check for you. Have you tried contacting the software company? They would be the ones who could tell you for sure if it can do that or not! Would love to see some pics of the bikes and pipes when you get them done!
Reply 6 years ago
Thanks for your prompt response,sent an email waiting with baited breath for a reply.My bikes are in bits at the minute,l will send you some photos when rebuilt
6 years ago
Can anyone help, I am keen to get started with my project, thanks ?
7 years ago on Introduction
Dont bother buying 2 Stroke Wizard. NO CUSTOMER BACKUP. I HAD IT AND IT STOPPED WORKING. Sent them many emails and got automated reply's but nothing from them. Dont waste your money. Plenty of free programs out there that work just as well if not better. Theires is all smoke screens.
Reply 6 years ago on Introduction
helo bro can you pls send me the 2 stroke wizard
Looks like it's still available here:
http://www.buildandclick.com/
8 years ago on Step 7
great work on the sheet roleing and math but you realy should have tig welded it and used a gas perge line inside the pipe with something to plug the ends then have a small hole to let the used argon excape .not bagging you by any means we don't all have acces to a tig I am sure it still worked awsome
good writeup. i enjoyed all the practical tips. thanks
9 years ago on Introduction
If it helps the engine visually looks like a YB100 which is rated as a 97cc I did have a go at cross referencing some of the engine parts but could only get some numbers for your bike and none for mine a main dealer might have better resources.
9 years ago on Step 3
Hi I'm a member of www.yammy100.com a UK forum and I can see your bike is a 100cc yamaha but not sure of the model there are a few of us that would like to make a tuned pipe, can you update the build on how well it works?
Cheers Rich.
