Introduction: Build a Wooden Nightstand
Enhance the enchantment of your bedroom with this unique wooden Nightstand!
Looking to give your bedroom a makeover? Dive into this DIY project offering a comprehensive, step-by-step guide on crafting your own wooden nightstand. While cutting the lumber might take a bit of time, the end result will be well worth the effort!
This nightstand measures 17” wide and 22” tall. Feel free to tailor it to your liking by editing the free 3D design. For a beautiful finish, we recommend sanding the entire piece before applying varnish.
Ideal for: bedrooms, living rooms and studios or offices.
Embark on this fresh woodworking project guaranteed to add a unique flair to any space it graces. Let's get started!
Instructions
A note before starting -
Please understand - the below diagrams are genuinely and carefully designed to help you navigate the build process. However, we don’t include specific recommendations for which tools, hardware, or products to use. These truly are “DIY” designs.
As such – a significant portion of the build-process will be up to you, the builder. So please know, there is no “right” or “wrong” way to assemble any of our designs! If you need to depart from the instructions, or rearrange things along the way, feel free to.
The only thing we ask: please be safe and use glasses and gloves while building. And of course, there’s no shame in asking an expert for help or seeking guidance from your local professionals at any time.
And please: enjoy the process!
- 4 2'' x 2'' Lumber - 22" Length Wood - Lumber
- 12 1'' x 2'' Lumber - 15" Length Wood - Lumber
- 12 1'' x 2'' Lumber - 17" Length Wood - Lumber
- 1 1'' x 2'' Lumber with 2 cuts at 45° - 4.25" Length Wood - Lumber
- 2 1'' x 2'' Lumber with 2 cuts at 45° - 10.75" Length Wood - Lumber
- 1 1'' x 2'' Lumber with 2 cuts at 45° - 17.5" Length Wood - Lumber
- 2 1'' x 2'' Lumber with 2 cuts at 45° - 24" Length Wood - Lumber
- 1 1'' x 2'' Lumber with 2 cuts at 45° - 4.5" Length Wood - Lumber
- 1 1'' x 2'' Lumber with 2 cuts at 45° - 17.25" Length Wood - Lumber
- 1 1'' x 4'' Lumber - 15" Length Wood - Lumber
- 1 1/2" Flange Black Steel Metal - Black Steel
- 1 1/2" x 1" Long Nipple Black Steel Metal - Black Steel
- 1 1/2” Female Threaded Lamp Adapter Black Steel Metal - Black Steel
Step 1: Crafting the Main Frames of the Nightstand
Using the parts list as your guide, you'll accurately mark the measurements on the wood. Then, employing either an electric saw or a hand saw, you'll meticulously cut each profile.
While this phase may be the longest, rest assured that with ample patience, you'll witness the results gradually taking shape.
Additionally, prioritize your safety throughout this step by wearing gloves and protective glasses to protect yourself.
Now that all the materials have been thoroughly cut and arranged, we're progressing to the assembly phase of the main frames. These frames consist of two 2x2 inch profiles, each measuring 22 inches long. To construct the frame, we'll affix two 1x2 inch profiles, each 15 inches long, at both the top and bottom.
Following this, we'll meticulously mark the placement of the remaining 1x2 inch profiles, also measuring 15 inches long. This step requires utmost caution, as precision is paramount for achieving optimal results.
Once all the markings have been meticulously done, we'll proceed to prepare the 15-inch profiles.
Carefully positioning each profile in its designated spot, we'll then nail them in place. Using a square, we'll ensure precise alignment by transferring measurements from one frame to another. Exercise caution and patience during this stage to ensure a snug fit for each profile.
Subsequently, we'll follow the same procedure for the remaining 15-inch profiles, pre-nailing 1 1/2-inch nails into them. Once all profiles are prepared, it's time to securely nail each one into its designated position.
Remember that if you have any type of doubt about the construction of this project, you can always corroborate the measurements and the construction process in the 3D model that I showed you at the beginning.
Once you've nailed the final profile into place, the end result will resemble this!
Step 2: Building the Nightstand’s Main Structure
Next, we'll proceed to prepare the 1x2 inch profiles, each measuring 17 inches in length, and we'll repeat the same process of affixing them with their corresponding nails.
Once all the profiles are prepared, we'll attach four 17-inch profiles to both the top and bottom of the frames to establish a sturdy structure.
To fill in any remaining gaps, we'll utilize the 17-inch profiles and secure each one into its designated position.
At this stage, our project begins to take form, and with the preceding profiles in position, the outcome resembles this.
Step 3: Making the Top Section of Our Nightstand
Now, our focus shifts to preparing the profiles destined for the top section of our nightstand, requiring specialized profiles with 45-degree cuts. We'll need two 24-inch profiles, two 17.25-inch profiles, two 10.75-inch profiles, and two 4.25-inch profiles.
Once the profiles are marked, we'll proceed to cut the angles and then refine any rough edges and excess material with sandpaper.
This step of the process is straightforward: marking and cutting the angles, followed by nailing each profile into place using 1.5-inch nails.
Exercise caution in ensuring even distribution, as the grid should appear symmetrical and uniform. Upon completing this process, the outcome resembles this:
Step 4: The Electrical Component of the Nightstand
Now, let's shift our attention to the electrical aspect of our project, as it's designed to be illuminated. After securely fastening the ends of our cable, we'll affix the socket onto a 15-inch profile. Subsequently, we'll attach the cable to a rubber contact and then simply nail the 15-inch profile onto the bottom of our main assembly.
Step 5: The Final Touches of the Nightstand
Next comes the most enjoyable part: applying the finishing touches! Choose the desired shade of varnish and ensure to coat every piece of lumber meticulously for a splendid appearance. Keep in mind that varnish emits a strong odor, so it's advisable to wear a mask during this stage of the process.
Step 6: Design Your Own Wooden Nightstand
If you want to make any adjustments to this Wooden Nightstand 3D Model, remember you can always visit our design app for DIYers modify or create your own project for Wood, PVC, Aluminum, or T-Slot Aluminum.
Is there any design you would like to see? Please leave us a comment.
Thank you for reading and watching the video!
