Build a Compost Bin From Pallets
Intro: Build a Compost Bin From Pallets
You want to build two big compost bins, but you don't want to spend a lot of money? So this project is for you, since it's entierly made of pallet wood.
You are welcome to watch the video (in german).
More details and free plans are available on my (german) blog: Build a compost bin from pallets
STEP 1: Take the Pallets Apart
Take the pallets apart. Crowbar, hammer an pliers are the right tools for this job.
STEP 2: The Plan
The compost bins should fullfill this requirements:
- self-supporting
- easy to change single boards
- front boards removable
STEP 3: Time to Switch on the Saw
First the boards are cut to length. Then notches for the normal boards are cut. Finally the diagonal notches for the front boards are cut with the jigsaw.
STEP 4: Cut and Glue Up the Poles
The poles are glued up from individual pieces. I'm using construction adhesive here, since it's strong and water proof.
STEP 5: Set-up the Compost Bins
Finally all pieces are ready and it's time to do the lego work and set-up the two compost bins.
5 Comments
atillakocsis 8 years ago
How many pallets are needed? I see each side has 7 planks, so that 28 total plus corners. Should i get 4-5 if the palette has 7 top planks and less bottom planks?
ernstp 8 years ago
jennifersculpts 8 years ago
This is a great compost bin. We built one with sides slightly spaced, but not removable & a lift-up door at the bottom. When we moved it was full (compost on the bottom, newer materials on top) & could be budged, so we gave it to our neighbor. Well, we need a new one & boyfriend is taking too long. I'll be breaking out the tools in the next day or so to get it done. Throwing away way too much! Thanks for a wonderful tutorial of a compost bin that is both very functional & nice to look at. One question: did you line it with chicken wire or similar to keep critters out?
craftclarity 9 years ago
I bet this gets added to my "honey-do" list pretty soon....nice work!
kc8hps 9 years ago
