Introduction: Build an IoT Plant Monitoring System With MicroBit and Grove WiFi Module
About: Hello there, I'm Abdulrahman Ahamed, a mechatronic engineer at Universiti Malaysia Pahang. I love making cool projects using different types of microcontrollers!
IoT-based Smart Farming improves the entire Agriculture system by monitoring the field in real-time. Come join me in this tutorial to learn how to keep track of your plant soil moisture with the use of the MicroBit and Grove WiFi Module, from anywhere in the world! 💦🌱
Step 1: Connection
By following the diagram above:
  • Connect the grove wifi module to P15 and P16
  • Connect the analog pin (A0) of soil moisture sensor to P1
Step 2: Code
Now, connect your REKA:BIT to your device and open MakeCode editor to start programming.
  • Add “ESP8266 Cytron” extension and follow the code block in the picture above
  • After completing the code, download it on microbit
You can also view and edit the code by clicking here!
Step 3: Data Logging and Monitoring Using ThingSpeak
Follow the steps here to create a channel in ThingSpeak and get the API key to store your data in the cloud.
If you want to learn more on how to send data to ThingSpeak using MicroBit with grove WiFi module, please check the video tutorial here
Step 4: Project Complete
Upon completing the project successfully, the reading value of the sensor should appear in your channel at ThingSpeak.
Note: The dryer the soil, the higher the reading value.
