Build Your Own Storytime Bear
Intro: Build Your Own Storytime Bear
The holidays are coming up!
I've got a great idea for a fun gift for that favorite preschooler, and you'll learn how to make things talk at the same time!
Let me introduce you to Storytime Bear, the stuffed animal that can sing, tell stories, or say anything you want.
Storytime Bear is powered by the Propeller microcontroller and speaks using pre-recorded .wav files from a microSD card.
Here's what you'll need to create Storytime Bear:
- The "Open Source" Pocket Mini Computer (Or replicate the audio, keyboard, VGA and microSD sections of that project)
- A 4 cell AA battery pack
- A USB cable with "micro" end.
- A Servo cable
- A 40pin male pin header
- A 10K resistor
- A small piece of "perf" board
- A small amplified speaker
- A stuff animal with at least one trigger button. (Mine has it in the paw)
STEP 1: Storytime Bear
My previously loved Storytime Bear was obtained from a second hand shop, and now lives a second lifetime in this Instructable to teach you how to make things talk using the Propellerpowered Pocket Mini Computer. I carefully removed his original innards which included two motor with moved his guitar and head as well as a small board with an extremely annoying version of something like Turkey in the Straw". No wonder he found he way there!
In this build, I focus primarily on the "talking/singing" aspect, but there is no reason why this project couldn't be expanded to include transistor controlled movement using the original motors. (I'm saving that for another project)
As long as your "Bear" has one push button somewhere, we're good to go!
STEP 2: The Pocket Mini Computer
You might be scratching your head at the requirement of a Pocket Mini Computer.
What's a Pocket Mini Computer? I'm glad you asked!
The Pocket Mini Computer is an open source "mini computer" design which uses the Parallax Propeller microcontroller as it's brain. The kit from Propellerpowered.com comes pre-loaded with a retro-style BASIC. The hardware itself is extremely powerful & featured.
The Pocket Mini Computer is quite a bit more advanced than the COSMAC VIP.
Here's the specs:
The Pocket Mini Computer is language compatible with Spin, Assembly (PASM), C, and BASIC.
COLOR BASIC features:
More details about the Pocket Mini Computer can be found on this Wiki.
Schematics and Souce Code are avaible for anyone who wants to "roll their own".
Here's the specs:
- The Pocket Mini Computer hardware specifications:
- Parallax Propeller Quickstart Board (8 cogs, 32K RAM, 64K EEPROM)
- Improved VGA Output
- Stereo R/L Audio Output
- PS/2 Keyboard/Mouse Input
- Wii(tm) compatible controller connection
- Optional microSD adapter connector
- Optional iR connector
- Experimenter's port
- 4094 available bytes free
- 64 colors
- 1 "SIDlike" audio channel
- 127 character re-programmable character set
- plot, line, and box graphics commands
- I/O access commands
- 95+ BASIC Commands, operators, and functions
- SD operating system
- Full screen editor (requires a microSD card.)
- Ability to execute non-basic binary programs
- Extended memory features (requires a 23K256 SRAM chip)
STEP 3: Connecting the Switch
Once you've removed all the "guts" from your stuffed animal, you'll need to locate the two switch wires coming from the switch.
I used a small piece of "perf" board to create a simple switch interface which plugs into the "Experimenter's Port" on the Pocket Mini Computer. The circuit uses a single 10k resistor to keep the switch circuit from "bouncing" switch states.
A servo cable is a perfect way to connect this circuit to your bear. Since I repair computers for a living, a grabbed an old reset switch connection from an old computer case to give the switch from the bear a nice plug for my board. The image on this page should provide everything you need to create this simple circuit.
Required parts:
Required parts:
- A Servo Cable
- 1 small piece of "perf" board
- 1 10k resistor
- 1 40pin male pin header
STEP 4: Battery Power for Your Pocket Mini Computer
The Pocket Mini Computer usually uses a USB power supply, or a USB programming connection to get it's power. Our Storytime Bear needs to be portable, so I'm going to show you a "Quick & Dirty" way to adapter your PMC kit to battery power. The Pocket Mini Computer/Quickstart is friendly to this kind of abuse, but please, don't use this to charge expensive cell phones, etc.
You need:
Cut the USB cable to expose the four wires, red, black, green, and white. Connect the red and black wires to the red and black wires of the battery pack. Solder, tape or shrink tube to protect the connections.
You need:
- A USB cable with a "micro" plug
- A 4cell "AA" battery pack
STEP 5: Testing Your Switch Circuit
Once you've got the switch circuit created, plug the other end of the servo cable into the Vss/3.3v/P12 connection on the Experimenter's port of the Pocket Mini Computer.
Type in the following program and run it to test your switch connection:
You should see a line of 0's until you press the switch, then you should see 1's until you let go.
Working? Perfect!
- 10 A=INT[12]
- 20 PRINT A
- 30 GOTO 10
Working? Perfect!
STEP 6: Time to Tell a Story
Time to give your Storytime Bear some personality!
This is the perfect project for someone who is going to be away from their children for any length of time. Hearing your voice tell their favorite bedtime story Reading to a child is one of those most powerful things we can do to influence a young lifelong love of reading.
We'll be using a free program called Audacity (download) to record our story, and convert it to the proper format for our project.
Once you've recorded your favorite story, use the following to save it in the correct format: (Refer to the image)
When saving the file, call it "story.wav" and move that file to the Pocket Mini Computer's microSD card.
- Click on the "Name Tab" pulldown
- Select "Set Sample Format"
- Select "16-bit PCM"
- Click on "File"
- Click on "Export.."
STEP 7: Putting It All Together!
Time to make our Storytime Bear actually tell a story!
Since we're using the Pocket Mini Computer, all we need now is a simple program written in BASIC. You'll also need to download and copy PLAY.BIN (The wav-player binary for PMC) to the microSD card.
Type in and RUN the following program:
Congratulations! You've got a wonderful give for that favorite child!
- 10 HOLD
- 20 A=INA[12]
- 30 IF A = 1 THEN BRUN "PLAY.BIN" STORY.WAV
- 40 FOR X = 1 TO 1000
- 50 NEXT X
- 60 GOTO 20
STEP 8: Credits
Once you've got everything working! Carefully stuff the PMC, battery pack, and portable speaker inside and close him up!
He's ready to go!
Credits: Without the resources of several people who have provided MIT licensed objects, projects like this wouldn't be possible!
BASIC/WAV PLAYER on the Pocket Mini Computer thanks:
There is a dedicated forum to Pocket Mini Computer. Regardless if you built the kit, or "rolled your own" drop in and join the conversation!
He's ready to go!
- Mike Green - FemtoBASIC
- Tomas Rokicki - FemtoBASIC, & FSWR
- Marko Lukat - Despair & Hope VGA
- Jon Williams - Wii Controller & Wav Player
- Johannes Ahlebrand - TinySynth
- Michael Park - Edit
- Andre' LaMothe - SRAM
amandaghassaei 11 years ago
