Introduction: Build Your Own Soundproof Studio in 11 Easy Steps
Thanks to constant advancements in digital technology, everyone can record at home, and everyone can own a studio. But while many settle for an eggbox-clad bedroom setup (a myth we'll debunk later), there is another way…
Build your own professional-quality recording studio. Yes, it's a Mohammed-style mountain to move and will require a sizeable investment of both time and money (and plasterboard) but the results could be priceless.
So, courtesy of MusicRadar.com here are the 11 most-important factors to consider when building your own studio. From soundproofing to floating floors to, er... breathing.
Step 1: Location, Location, Location
The first consideration when contemplating building a studio is where to build it. At this stage it's important to consider just how loud you're going to be (especially your drum kit) and how viable soundproofing is for your situation.
For example, converting a garage in your garden will probably leave a decent amount of space inside after soundproofing, with minimal noise escaping. However, a room in a house or flat may be impossible to soundproof completely and leave you unreasonably cramped after doing so.
Step 2: Let in the Light
Daylight is such an important ingredient when it comes to creating a nice place to work in, and a lack of it can make your workplace feel like a prison cell. It's easy to assume that blocking up windows is the only option when soundproofing a room, yet a combination of a single double glazed unit with no opening windows and a sheet of acoustic glass (comprising of two sheets of glass with a thinner sheet glued inbetween) will work incredibly well if installed and sealed correctly.
Step 3: Close (and Seal) the Doors
Your studio will have at least one doorway to contend with and, like the window, this is another potential area for sound leakage. Simply using a heavy door can help, though adding weight by building a regular door up or applying a layer of Sheetblok (a special vinyl material designed to act as an effective sound isolation barrier) can have the same effect.
Make sure each door seals completely when shut – regular sealing strips are available from DIY stores, but there are sets commercially available specifically for this purpose.
Step 4: Don't Forget to Breath
With all of the windows and doors sealed and walls caulked and airtight, there is the small issue of how you're going to breathe. Surprisingly easily overlooked, the supply of air into the studio is important, not only to avoid lapsing into unconsciousness mid-paradiddle, but also for the preservation of the recording equipment, on which moisture can collect.
You'll need both an inlet and an outlet (one with a fan), spaced evenly apart of possible.
Step 5: Build an Acoustic Box (hello, MDF)
In creating these air vents you'll now have a hole in your soundproofing that will need an acoustic box built over it, one of which will house the fan. Make an 'S' shape duct within an MDF (or equivalent) box, line with acoustic foam and place over the vent holes along with some mesh to keep out unwanted crawly things.
One final consideration is to avoid putting the inlet vent where the sun shines, so to speak, as it will pull in unwanted hot air during the summer.
Step 6: Create a Room Within a Room (the Difficult Bit)
Most soundproofing is done with the 'room within a room' principle in mind: construct a separate room within the original building with minimal contact. If space allows, run a new wall of high-density concrete blocks internally, mounted on thin neoprene (a type of synthetic rubber compound) so that the blocks are not directly on the floor.
Tie them to the outer walls using acoustic wall ties and, once you have soundproofed the original roof using mineral wool placed between the beams and a couple of layers of plasterboard mounted on resilient channel, do the same thing again on a second roof mounted to the new internal wall.
These internal walls can then have 2x2 timber attached vertically, again mounted on neoprene, and after pushing in 2" thick mineral wool inbetween the studs, our two layers of plasterboard can be fitted onto resilient channel. Finally (phew!), all surfaces should be sealed with decorators caulk – a small hole in the surface, which can be caused by cracks around the surface of a wall, can compromise its efficiency by up to 50 percent.
Step 7: Don't Hide the Power
It's often assumed that power and lighting cables should be run behind the new plasterboard walls. However, cutting out plug sockets will destroy your carefully built soundproofing. Instead it's recommended that all power is surface mounted using conduit or trunking, or you could build out another area for light, plugs and power using timber and plasterboard.
Step 8: Use Floating Floors (another Difficult Bit)
In essence, this is the same as we've done to the walls: decoupling two surfaces to prevent vibration being carried across. To float a floor, wooden beams can be placed on rubber U-Boat supports at regular intervals and, with neoprene strips inbetween, a chipboard floor can be screwed on top.
A much simpler and cheaper solution is to use PlatFoam to raise separate pieces of kit off the ground. PlatFoam comes in the form of long 3"x2" strips of high density foam which can be laid a few inches apart with a sheet of plywood placed on top to create a floating riser.
Step 9: Tune the Room (absorption and Diffusion)
Simply having the room carpeted and putting a sofa at one end will probably help, but to address the wall reflection you can use a combination of two solutions: absorption and diffusion.
Diffusion involves sending the reflections off in different directions, breaking up the sound, while absorption soaks up certain unwanted frequencies. This is where the old eggbox myth can be laid to rest – while their shape should make them potentially good sound diffusers, their material isn't reflective enough, and its absorptive properties are minimal too. They don't look very nice either!
So, try picking up some 2'x4' sheets of hardboard and make yourself some absorption panels using 1" slabs of mineral wool (the same size) placed over the top and a dustsheet laid over and tightly stapled from behind. They'll look better and, more importantly, will actually work when hung on opposite walls.
If you'd prefer to invest in something ready made for the job, try some Aurelex, ProFoam or similar. These companies make a range of products for studios and even make room packs with all the different elements you'll need for different sized rooms. As you'd expect, this comes at a price, but gives professional results both sonically and visually.
Step 10: One Room or Two?
If this soundproof space is to be used as a recording studio as well as a practice room, your next consideration is whether to go for a one-room studio or to have a separate control room. It may seem obvious that a recording studio needs two rooms, one to record in and one to listen back in, but for some musicians it can sometimes be easier to work in the same room as the equipment.
One compromise in this situation is running a second computer monitor into the live room and using a wireless keyboard and mouse to control things. This way each room can be tuned to it's optimum potential.
Step 11: Remember: Rome Wasn't Built in a Day
Building a studio can be a time-consuming process and you'll no doubt encounter setbacks along the way. As a result it can be frustrating as the time ticks by and costs add up, but try not to lose sight of the fact that once it's complete, the space is yours to create your own studio environment in.
You'll be free to play when you want without disturbing anyone and you can be as creative as you like. That's got be worth the effort hasn't it?
Thanks for reading, we'll be uploading more step-by-step tutorials to Instructables, but for all your other music-making needs, check out MusicRadar.com.
1 Person Made This Project!
- noah.schade.7 made it!
61 Comments
6 years ago on Step 11
Reading many Instructables, perhaps the majority show an appalling lack of grammar and the inability to effectively communicate a linear process in a clear manner. If one wishes to write up their project, it is essential to assume the reader has no understanding of the process and include each step, materials, sources, etc. so they can successfully complete the project. An Instructables author must proofread their work, by assuming the reader knows nothing. They must also carefully check their writing for mistakes in grammar, usage and spelling.
This Instructable was very good in the information presented, but could use some grammar checking and the author could have avoided some confusing instructions and lack of sources had he asked several friends to read it over. One thing he did not mention is to make the walls of the inner room asymmetrical in order to avoid a standing wave. Apart from this, I think he covered the major and minor points of soundproofing quite well. One suggestion is to use Green Glue to seal the drywall.
Reply 4 years ago
MartindeMadrid
I think your comment about standing waves is OK but with suitable sound
absorption on the walls any reflections will be dampened enough not to
have to worry about asymmetrical walls. If there isn't any sound
absorption then asymmetry will just produce longer paths and even
ignoring those it will not sound good anyway. We are talking about waves
from around 17mm at high frequencies out to 17 meters at low
frequencies. I know after years of playing the high frequencies just go
in one ear and out the other (a bit of silly humour there) anyway,
standing or sitting (the waves that is). I'd go with decent sound
absorption on the walls to stop reflections rather than the extra work
of out of square walls which loose precious space.
Reply 4 weeks ago
Would a temporary retractable wall suffice?
Reply 5 years ago
Bravo MartindeMadrid, well said
Question 7 weeks ago on Step 4
Which wood is used to make all that frames to fill the insulation?
5 years ago
Cry out because you do not need much to make a recording studio
All you need is 1.A computer
2. music software (Reason 5 is perfect)
3.Midi keyboard (m audio air 32 is great)
4.Audio interface (maudio is voila in this case).
5.Microphones (condenser is great but dynamic is gonna work cool)
6.Pop Filter (obviously needed to replace soundproofing of walls).
7.Some great speakers.
8.many sets of wires to connect
To avoid soundproof you need good pop filter of $6 but you can even make it in home by watching some youtube videos and thats gonna work cool.
The most expensive
1.audio interface
2.Condenser microphones(optional)
THANK YOU
Reply 2 years ago
You can make a "workstation" with just a computer, etc, but don't fool yourself into thinking it's a studio. Which condensor mic should the horn section set up in front of lol?
A real recording studio can record live musicians on separate tracks, and overdub, punch-in, etc. I think this article on soundproofing a room for a studio is pretty good, especially the parts about decoupling.
Reply 5 years ago
someone needs to do a little more research before pretending they know things...a pop filter has ABSOLUTELY NOTHING to do with soundproofing!
Reply 4 years ago
THANK YOU lol
Reply 5 years ago
I think you posted on the wrong thread.
Reply 4 years ago
LOL ha you are right
Reply 4 years ago
Yes you are listing important things for recording but not to get a soundproof room. THANK YOU
3 years ago
Step 4: Don't forget to... breath? (maybe you mean "BREATHE"?). Pretty in-depth. Is there any way to temporarily make a FREE soundproofing without having to spend hundreds and thousands of dollars and a whole lot of time?
4 years ago
Thanks for info. Im new to voice acting and need soundproof area for recording
5 years ago
I'm forwarding this to my drummer friend.
5 years ago on Introduction
Useful tips. Soundproofing is necessary for creating beautiful and effective acoustic environment. Well-planned acoustic design provides good sound experience in homes and commercial spaces. It will help to solve the problem of noise in studio. You can check out this link for more details on soundproofing.
Source: http://www.kamak.se/anvand-snygga-ljudabsorbenter-for-att-forbattra-akustiken/
6 years ago on Introduction
Great project, thanks!. And thanks for the hearty chuckle, " ...avoid lapsing into unconsciousness mid-paradiddle." Ha Ha, that's perfect.
7 years ago on Introduction
https://soundcloud.com/hannah_wants/hannah-wants-mixtape-0713
7 years ago on Step 11
How much did this project cost for you?
8 years ago on Introduction
I've been working on my own studio build, to www.voiceofmonk.blogspot.com to follow along. Roxul60 is the insulation material, great stuff!
