Introduction: Building Blocks Made With AI
Hi!
I am currently a student in GEMS Millennium School, Sharjah. Today, I have made a model of a building block, using Tinkercad. You can use design this project by following the given steps. However, while making this project, proper measures must be taken.
Have you ever wanted to create an architectural model? Well, you're in luck because in this step-by-step guide, I'll show you how to create this building block, which can be used for creating architectural models!
Having said that, let's get started on this journey of creativity and craftsmanship!!
I have used the 3D modelling website Tinkercad for making this project as discussed above. This is a very easy to make, efficient and useful project.
Step 1: Designing the Blocks
This is our very first step in our journey to make this project:
  1. Open Tinkercad.
  2. Click on the 'box' button, present in the 'Basic Shapes' column.
  3. Now, we change its dimensions, to make it as shown in the picture, above for your reference.
  4. Click on the 'box' option again, and give it the same dimensions as the first box.
  5. Finally, place both the blocks opposite each other.
Step 1: Complete!
Step 2: Joining the Block
Now, we move on to the second step:
  1. Click on the 'cylinder' option in the 'Basic Shapes' column.
  2. Give it the required dimensions to make it as shown in the image.
  3. Now we move the cylinder in between the two boxes, such that it is joined to both the blocks, connecting them.
  4. You can also add a 'tube' from basic shapes as shown in the image.
Optional: Give the blocks and cylinder your favourite color, to customize the block!
Step 3: Adding the Connectors
This is perhaps the most important step in this project:
  1. Create a small 'cylinder' from the 'Basic Shapes' column.
  2. Connect this cylinder to the cylinder we created in the previous step as shown in the image.
  3. Now, create a 'tube' from the 'Basic Shapes' column and give it dimensions as shown in the image.
  4. Then add it to the other side of the cylinder we created in the previous step.
This step is very important, as it allows this block to be connected to other blocks.
Once again, you can give it any color.
Step 4: Summary
I hope that you have successfuly made this useful project, I made with AI. Congratulations on your success!!!
Thank you for this reading instructable!
