Introduction: Building Custom Shop Counters | Cash Wraps
In this instructable you will see how I built three different custom counters for a sweet shop, with raised panels out of ply and matchboard!
Step 1:
Firstly, I cut to the right length, all the pinewood pieces I needed for the three counters.
Step 2:
And then, I cut them to the right width.
Step 3:
Now, I started to assemble all the bases of every counter.
Step 4:
I checked that every piece is perfectly square and then drilled it and screwed it.
Step 5:
After I had nailed and screwed every piece, I rounded all the edges with a router, I puttied all the screw holes and sanded them very well. I repeated the same process for the other two.
Step 6:
Now, I started to sand all the pieces that I was going to use to create the raised panels.
Step 7:
And then for each piece, I rounded its sides where necessary.
Step 8:
In order to create raised panels, I used my router and I made a 1cm slot (as the thickness of the matchboard & the ply) in the middle of every piece.
Step 9:
And I tested that the matchboard fits nice and without any problem into the slots!
Step 10:
I puttied every piece separately and then sanded it very well.
Step 11:
Also, I cut and sanded all the plywood pieces that I was going to use for the upper part of the raised panels.
Step 12:
Now, I started to assemble all the rail and the stile pieces together. After that, I screwed them onto the beams.
Step 13:
I placed one beam at every corner on the base of every custom counter.
Step 14:
And then, I put the matchboard and the plywood pieces into the slots I created before.
Step 15:
I screwed them on the upper part of the counter, in order to make one solid steady piece and then puttied all the screw holes.
Step 16:
Now, I cut the top surface of every counter to the right dimensions and then I rounded all the edges. For the countertop I used 3cm thick veneered MDF board (Oak).
Step 17:
I sanded it with many different sandpapers very well, on all four sides and then I repeated the same process for the other two countertops.
Step 18:
And then, I started to paint all the counters on every side with ecological water based undercoat / primer.
Step 19:
I filled all the gaps with putty (a lot of putties…), sanded them very well and applied premium quality water based enamel paint on the last layer!
Step 20:
...and the Custom Shop Counters are ready!
Thanks for reading! I hope you liked it!
