Introduction: Building Sawhorses Done in 14 Minutes
Building sawhorses - Useful home-made literally from firewood, a door hinge and a piece of chain. Everyone can assemble, you will need a minimum of tool.
Step 1: I Still Have Trimmed Boards, Laid the Floors, Took the Board 150 * 40. Making Goats From Such a Board Will Be Too Cumbersome.
Step 2: Therefore, We Measure Out 100 Mm.
Step 3: and We Open the Board, There Will Still Be Bars of 50 Mm. 😉
Step 4: We Twist, Adjust to Size, I Did 80 Cm. for My Purposes, This Is the Ideal Height.
Step 5: We Take Two Boards and Make a Cut at 30 Degrees.
Step 6: We Connect Them Together Using a Door Hinge.
Step 7: We Take a Chain, You Can Replace It With a Cable, But I Have Long Had 5 Meters of This Chain Lying Around.
Step 8: It Will Be in the Role of a Limiter in Width, Legs Made at 30 Degrees.
Step 9: on Both Sides We Install the Crossbar.
Step 10: You Can Add a Lower Crossbar, But for My Tasks, It Is Not Required.
Step 11: Here Is Such a Convenient Option, They Add Up Quickly, Reliable, You Can Do It in Literally 30 Minutes.
Step 12: And So They Look in a Working Position.
Step 13: Withstand a Load of More Than 100 Kg. Already Verified Personally.
Step 14: Video Version
If you liked this project, then be sure to subscribe to my YouTube channel and check out some of my other Instructables.
