Introduction: Building Your Own Temperature-Controlled Fan With DHT11 Sensor
Hello Makers...
- today we will start making an amazing arduino project for learning arduino concepts and helps you to develop projects in future.
- project is very easy to make and the concept behind project is when we set threshold temperature when atmosphere temperature crosses threshold temperature it detects using temperature sensor and it turns on fan.
- I also provide video link above so you can follow that also if any trouble cause.
- Now without wasting much time let's get started..
Here are list of components required for making this project :
1x Arduino UNO
1x I2C Display
1x DHT11 sensor module
1x Potentiometer 10k (you can use any other also but have to change some lines of code and calculations)
1x mini breadboard (or can use pcb also)
1x dc small 5v fan (for project we use this if you want to use in daily life then will have to use relay module)
1x 5-12v power supply
1x jumper wires
now lets start with our step1
Step 1: Connections
click here to download connections image
follow the above diagram for connections. it is bit confusing but to make connections simple we use mini breadboard so we can provide VCC and GND to all components.
FOLOW BELOW STEPS FOR BETTER UNDERSTANDING:
I2C - Arduino
VCC - VCC
GND - GND
SDA - A4
SCL - A5
DHT11 - ARDUINO
VCC - VCC
SIGNAL- D2
GND - GND
POTENTIOMETER
PIN1 - GND
PIN2 - A0
PIN3 - VCC
DC fan
Red wire - D3
Gnd - Gnd
Step 2: FITTING ALL COMPONENTS
I use cardboard sheet you can use any other board also to fit all components
after fitting all components in cardboard using zip tie all jumper wires to make it looks well looking.
Step 3:
click here to download code
After download code copy it and paste it in arduino IDE software
connect arduino with PC.
select board and port then compile and upload it.
now your board is ready to work
Step 4: Working
Now our project is ready to use
To power it i use 12v adapter you can also use battery to make portable.
as you can see in picture we have to set threshold temperature and whenever temperature rises above threshold temperature fan will turn on until temperature comes below threshold temperature.
that's for today I hope you learn something new we will back soon with new project with new idea
Have a nice day Makers ;)
