Introduction: Building a Bird House
Here’s the steps of for building our bird house
Step 1: Measurements of Wood
Floor:
150mm by 120mm
Sides:
1 side is 200mm by 150mm the other side is 250mm by 150mm
Roof:
220mm by 150mm
Back:
300mm by 150mm
Front:
200mm by 150mm
In total plank length:
1290mm
150mm by 120mm
Sides:
Roof:
220mm by 150mm
Back:
300mm by 150mm
Front:
200mm by 150mm
1290mm
Step 2: Cutting
Use the Miter saw in the workshop to cut the pieces of wood
Step 3: First Sanding
After cutting you are going to use the belt sander to sand down all of your pieces
Step 4: Drill Pilot Holes
You use a drill and drill bit to be able to make the holes in your wood
Step 5: Drilling It
Change your drill bit to a Phillips head and drill 1/2 inch screws into the pilot holes
Step 6: Second Time Sanding
For this sanding you use a hand sander to sand your final project
Step 7: Staining
Use a staining sponge and use the stain water guard waterproofing clear sealant
