Building a Gypsy Wagon
941,237
1,928
264
Introduction: Building a Gypsy Wagon
About: Naturalist, scientist, builder, and maker.
For many years I have been interested in Gypsy Wagons or "vardos" and western sheepherder wagons. As it isn't practical for me to have an authentic, horse-drawn lifestyle I decided to make a version towable at highway speeds. After reading just about every book I could find on wagons, caravans, old-school RV construction and trailers, a model began to take shape in my head. For me, it needed to be short and maneuverable, sleep two to three people, and still have the air of old world craftsmanship. This meant not looking like a modern RV. My secondary goal was that it should cost as little as possible without sacrificing sturdiness or basic comfort. Finally, I decided on wood as the primary building material as that is what I am familiar with and is definitely a very cozy and comfortable medium for a living space.
Most of the actual work was performed with a table saw, band saw, drill, and a slew of hand tools as I found time around my day job. Although I don't really consider it "done", it is complete enough to use and is currently on the road.
Step 1: The Mock-up
After about fifty sketches and lots of graph paper renderings, I decided I needed to visualize this in three dimensions. Here is my cardboard mock-up of the final design. An earlier version is visible behind it but this one had a lot of appeal for me. My requirements were 7' width for sleeping cross-ways, 8-10' long, and enough height to stand up in. A collapsible bed and table allow for a shorter overall wagon. The first drawing above probably gives the most accurate dimensions for the final product. You can see some changes in design even as I approached the final product.
Step 2: Trailer Conversion
I found a sturdy little cargo trailer with a heavy duty frame and tongue. The first step was to cut off the box with a reciprocating saw and grinder. I intended to save the wiring harness and lights but they proved to be outdated and fairly ratty.
Step 3: First Cuts
There was a huge sense of relief when I made the first cuts to create the brackets. After years of pondering, waiting, and changing plans, I felt committed. It was like I was starting an avalanche. No turning back now. I plunged into long evenings and weekends, cutting, fitting, and sawing. The base came together quickly after work one evening. Finally, the base was set on the newly painted frame and through-bolted for strength and safety.
Step 4: Walls
The walls are built like a box, not like modern stick framing. All are tongue and groove pine, the front and rear being 3/4" thick, the sides 1/4". This is why the sides have hardwood strengthening battens (1") run vertically inside and out on 1' centers. Corner posts are made from 1 1/4" pine stock. Outside corners are oak. Upright bracing around the door inside and out from poplar. Upright bracing on front wall is oak. Sub-floor is 1" salvaged plywood.
Footnote: I have since put a second layer of wood over the outside side-walls. This added some strength (and at least 40 pounds) but was primarily to add insulation for heat transfer. The walls get incredibly hot in the southwestern sun and transferred much of the heat inside. I didn't really notice a problem in the cold as the wagon is quite snug.
Step 5: Internal Structure and Roof
The bed structure ties the walls together and stiffens the entire structure. Without this, I would have to find some other way to strengthen the walls. The roof is plywood, screwed to poplar purlins. Outer and inner tops of walls are stiffened with oak band boards.
Step 6: Table, Window, and Door
The table is modeled after those in old British wagons. The window was made as a separate unit and then attached whole to the wagon body. It is oak and pine. The door is modeled after some sheep wagon styles from the western U.S. It is a "Dutch door" with a functional casement window and a wash pan holder. Not quite finished in the photo below but nearly there.
Step 7: A Trial Run and Some Finishing Touches
We took her on a 500 mile journey into the desert to test her out and figure out some interior layout issues. We got a base coat of oil paint on most of the body by the end of the week. After we returned, we added an oak floor, finished the table, and added a lot of homey touches. There ample storage under the beds, but I intend to add more outside.
Step 8: Stairs, Paint, and Shelving
Stairs were built to match wagon. Oak treads, fir risers. The paint was still proceeding slowly at this point but we had to take some time off to head to the ocean for a second "test" journey. The wagon traveled across New Mexico, Arizona, and southern California through the scorching desert to the beautiful San Diego area for a week. When we got back, she got her full coat of paint, and some more interior work. The shelves are an enormous amount of space, and can be covered by a roman shade type cover.
Roof: Although I didn't photograph this step, the roof was ultimately covered in a low profile steel that was epoxy coated in the factory. It is a light color to keep some of the radiant heat out and seems to work well. It is screwed through the roof into the purlins.
Step 9: The Stove
With autumn here I felt it was time to deal with the dreaded stove. I made a hearth area in the corner, tiled the riser with slate, covered the walls with 14 gauge flashing, covered that with fire shield board, inserted a wall thimble, and placed the pipe and stove in the wagon. In case of rough driving conditions, the stove is screwed to the deck, and two large eye screws attach it to the back wall. It is unlikely to move in anything short of a rollover. The stove is from Four Dog Stoves and is probably too big for this space. Its what I had though.
Step 10: On the Road
This is the wagon being used on the road. I have fired up the stove and have spent about three weeks worth of nights in it by the time this photo was taken. It is all I could ask for. I added three outside boxes, two pictured below, for extra space and for things that don't need to be inside. Two more boxes were added later.
Step 11: Living Space
Only with time will the wagon really take on a personality as it get lived in and things are arranged "just so". Like a ship or any small living space, a good deal of thought needs to go into every little detail, especially when it comes to storage. I think it will help me minimize and is now my real "escape pod", whether its to get to the mountains or beach, or to just someday hit the road. Here is a three photo pan to give a feel for the space.
There are a few more photos of the rig and other stuff on my weblog at http://paleotool.wordpress.com/ under "projects" and "vardo". It will be updated as it is continually improved.
Step 12: After 9000 Miles...
Here she is after 9000+ miles and more improvements. Its a continuing process that I hope to perfect in the next decade or so. The paint is still not finished in this photo but most of the exterior construction is finished here. Thanks for looking around. More at http://paleotool.wordpress.com. Happy travels.
Step 13: And a 20,000 Mile Update...
New cedar siding and windows for 2014. More varnish and paint to keep things fresh and protected.
Woodworking Contest
Grand Prize in the
Woodworking Contest
9 People Made This Project!
  • For the Home Contest
  • Make It Bridge
    Make It Bridge
  • Game Design: Student Design Challenge
264 Comments
mcbrasi
mcbrasi
Question 4 weeks ago on Step 13
This is awesome! How much did it weigh in the end?
Rachel Ludgater-Mitchell
Question 6 weeks ago on Introduction
Hi there, Sorry but I just had to message you, after so long working on my design, it's almost as if you looked inside my head & created my design for me. I couldn't explain it to people, because I too picked many of the same ideas from all of the different traditional methods & it looks as though, your choices were based on the same things needed for your circumstances as mine. As a result, I hope you won't mind me picking your brain as I go please? This is my starting point. I was wondering about wheels & tyres though. Something road worthy, but that won't leave me stuck or sinking in the grass & mud, once I've added more weight to the trailer. I'm hoping to not have to move them & the single axle forward, but as with all of it, I'd love to read your thoughts, please?
Many thanks, Rachel
P.S. I'm in the U.K. so a much wetter climate, than yourself☺️
Screenshot_20230121-191805.jpgScreenshot_20230121_192720_Facebook.jpgScreenshot_20230121_192727_Facebook.jpgScreenshot_20230121_192737_Facebook.jpg
harleyquinnhair
harleyquinnhair
1 year ago
If I wanted to make a gypsy trailer with a salon chair and a shampoo bowl, nothing too fancy, any idea what it may cost? I already have the salon chair lol
Kennyc81
Kennyc81
Reply 1 year ago
Look forward to spending 2000 dollars or more. I highly recommend buying a flat bed trailer already assembled. It will save you a lot of time.
LibbyTheBedford
LibbyTheBedford
3 years ago on Step 4
Hi
Thank you for all the information you shared!
I am just starting on my journey. Can I just ask about the second skin and heat transfer you mentioned please? I have an old horsebox I am fixing up. I have looked into insulation and found something I am happy with but I was just wondering what would happen if I didn't insulate at all and just had the existing single wooden skin? I am in the UK and will be using lpg for cooking and heating so there will be a bit of moisture. There are also currently 4 vents, there will also be a stable door and 2 opening windows.
Many thanks
RobynS47
RobynS47
Tip 3 years ago
I made my gypsy wagon with hand tools. I have a facebook group called Australian Gypsy. I am in my 70s. If I can do it you can too. I love the positive comments I get while travelling. It is 2 meters wide by 2.5 meters long. It travels well, but does not like bumpy roads.
Theelax42
Theelax42
Question 3 years ago on Step 13
how does it handle on the road? how fast do you take it?
Mr_corruptex
Mr_corruptex
How much do you estimate the build cost you and how do you think you could've saved money or time in retrospect?
hoggem
hoggem
Question 4 years ago on Introduction
what did you use for the extra layer on side walls and how was that attached?
kev1n1956
kev1n1956
4 years ago on Step 9
I fell in love with your design and built one from your pictures. Haven't finished the inside yet, the roof or installed the windows, but it's coming along nicely. Thank you for putting your work out there ! It sure inspired me.
paleotool
paleotool
Reply 4 years ago
Hey Kevin, Thanks for the comment. Your project is looking great. I can't wait to see the rest.
AnneK55
AnneK55
How much did the vardo weigh when you were done ?
jsims18
jsims18
Question 4 years ago on Step 3
how did you attach the base and how much did the supplies cost you
MaryB190
MaryB190
5 years ago
How did it handle the heat without any insulation? Also how did you keep food cold? Did not see a fridg or cooler.
Swansong
Swansong
5 years ago
Awesome camper! I'd love to make one of these some day :)
photony
photony
6 years ago
I'm dying to make one, but I'd like it smaller, for my Honda CR-V, and even possibly behind a motorcycle!
EmmaB65
EmmaB65
6 years ago
I love it! I'm just in the process of beginning a project myself using an old farm trailer. I don't plan tow the van anywhere but would like to think it is roadworthy if I need to. Are there any rules?
If anyone is interested, this is my project:
smallspacebigplans.com
ClareP6
ClareP6
6 years ago
Hi, I have made a gypsy bow top and am now looking at trying my hand at a reading gypsy caravan on an old caravan chassis so it can be towed holiday. I'm sure I can do the main build but need some pointers on how to make a molly croft roof. Help anybody ?
DaviR5
DaviR5
7 years ago
I am seriously thinking of converting one of my old flatbed trailers to a sheep wagon style camper. I'm a bit concerned about the size being too small though. It's 8 foot x 10 foot. How are you coping with the size on yours, and what is the actual size?
I'll try and post a pic of the trailer here
loskop100.
loskop100.
Reply 7 years ago
I built something similar many years ago, but more like a box on wheels. The biggest problem was created by the wheels being at the four corners meant that there was enough racking to tear the box apart. I replaced the dog trailer set up with a tandem axle set up but still got a lot of racking induced problems so I ended up replacing the two axles and using a single two ton rated axle out of the front of a Hino light truck and that worked for nearly ten years with only minor cracks appearing, now the box has been removed and I have been working on one of these gypsy thingos and apart from the chassis it is all timber.
